Jononomous
Hey All,
Got a used oscilloscope.. model BK Precision 100Mhz 2190A
I'm using the built-in square wave generator to calibrate the leads... and strangely it doesn't seem to be working correctly.
Here is a pic:
Shouldn't the square wave be larger? Also, the notch for the square wave gen says .5p-p... so I set the volt/div to .5 and its just a straight line... i had to crank the volts/div over to 5mV to get it to detect even this little wave... is something messed up? I messed with the timer knob... to get this wave or a slightly longer one I would use .5ms or .2ms respectively.
Did I buy a lemon or is there something I am doing wrong?
Here is a pic:
