Overclocked
This Time, Im building Some Lights To Light up My desk while I work, because I have this lamp is just a bit annoying. Im going to use white LEDs that I got a while ago from Ebay. Their a bit silverish, but they will do fine in lighting up what I want to light up. I dont really need that much of a wide angle either, So Normal 5mm LEDs will do Fine. Here are my requirements thusfar,
Vin = 1.5 to infinite (or some large value, doesnt matter)
Vout = 28V
Iout = 160 mA
IC Chosen: LT1618
https://www.linear.com/pc/productDetail.jsp?navId=H0,C1,C1003,C1094,C1766,P2079
LED strings will consist of the following; 8 in series with another 8 in parallel, which totals 16 LEDs. Total Current Per LED Lamp = 40mA (assuming 20mA Per String). Total Voltage = 28V (assuming 3.5V Per LED). There will be 4 LED Lamps, which brings my total current requirement up to 160mA.
Note: A LED Lamp is what will contain the 16 LEDs...made out of PVC.
Now it seems that there now is a rather large number of Boost Converters That Seem to Fit the picture, and because of that, Does anyone else Have any other IC's they have in Mind? Err Anything "better" per say. I know theres a whole crap load of boost converters out there, it was kinda hard choosing one, But I chose this one because of Ease of Use, Size, and Linearity of Efficiency.
One requirement though, Cannot Be QFTN or QFN Or Any other of those weird packages (they are square and have pads Underneath that a normal soldering iron cannot get too) . Can be SOIC, MSOP, SOP...etc. Can be Either SMD or Through hole.
Vout = 28V
Iout = 160 mA
IC Chosen: LT1618
