Hi everyone!
This is my first post here in quite some time. However, I have a quick question that I'm sure someone with a bit of savvy could answer easily
How do I output two different voltages with a comparator? For example, if I had an input that varied between 0 and 1 V and wanted an adjustable reference but I wanted to output 0.2(Low) or 0.8(high) Volts?
I was thinking of using two comparators both using the same input but each ones output was tied to a different voltage divider. The only problem with this is it would create conflicting signals on the output, or in other words, one would have to be off while the other is on... Does someone have a better suggestion?
Thanks A LOT in advance!
(By the way, I'd be using this to bias the oxygen sensor output on a car)
