Hi.
I am making a DIY 8-bit Gray-code optical absolute rotary encoder project and I'm 3 days into programming the PIC18LF4520 MCU with MPLAB IDE and the C18 compiler.
I have the 8 photo transistor output signal lines (one for each code 'ring' of the disc) as inputs to PORTA (RA0-7 LSB to MSB) of a PIC18LF4520. I am reading voltages on each of the PORTA pins (checked with multimeter).
What I want and have tried to do is basically convert/decode PORTA, which is receiving Gray-code input, to a decimal angular position. I wish to then print this value to a 16X2 LCD.
For now I'm not calculating the angular position, I just want to output the position of the disc in binary ie. position 0 (00000000), 1 (00000001), 2 (00000010) etc etc up to 255 (11111111).
e.g. at any given position PORTA will contain a positional Gray-code:
*PORTA = 0b00110101 (8-bit Gray-code) ......which is decimal 53
*convert to binary = 0b00100110 ......which is decimal 38
*output this decimal number to LCD connected to port D (I already have the LCD working to output strings and numbers),
The problem is I'm not quite getting the output I'm after on the LCD...and I don't think its just LCD formatting problems. I have at one time got a clean number 0-255 (8-bit) but the increment was not as expected is jumping from say 10 to 53, thus making me think I needed to adjust the disc/sensor alignment. But after carefully re-adjusting the disc and checking that I'm getting expected voltage on each pin of PORTA, I now have output like this: 227, 36:, 2:3, 236 and so on.....
View attachment LCD2.c
I have attached the code above. I know its a drag looking at other peoples code, so here is a summary of what I think are possible problem areas in my project/code:
(1)
Is the following permissable?
unsigned char GrayWindDir=0;
GrayWindDir=PORTA;
In my mind this will store the 8-bit gray number occuring on PORTA in variable GrayWindDir.....but im not convinced![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
(2)
I have tested the function LCDWriteInt(); but all variables holding the 8-bit numbers (like GrayWindDir and BinaryWindDir) I have made of type unsigned char. but LCDWriteInt() accepts integers....it did seem to work though.
Anyway any help or direction will be most appreciated![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
(1)
GrayWindDir=PORTA;
(2)
