P16F877, LM18298 and PWM to run 12V DC motor...Need Help!
yeeyk82
I need to fulfill the requirements of using P16F877, LM18298 h-bridge and PWM to make 2 DC motor go forward, backward and reverse. But i got minimum knowledge on this so need some help....
Can anyone guide me on this?
http://www.datasheetcatalog.com/datasheet/L/LM18298.shtml
You can role down this datasheet, and see the application information. You can make the circuit.
To turn the motor, you make pin3 and pin4 High/Low or Low/High.
But if you do so, you cannot control the velocity of the motor.
PWM help you this.
As you intend to make pin3 HIGH, and pin4 LOW, you give a pulse to pin3 with period upto 5KHz and the duty cycle can be open from 0 to 100% on pin3. This make your motor turn as pin3 HIGH, pin4LOW, but at lower speed. However, as you open duty cycle from 0% to 100%, you can control the velocity of the motor from stop to run at max speed.
