panasonic plasma th42 pz700
ronnieboy1
hello there, I have this set for repair, and when you switch on the green light flashes at the front constantly.,doesnt change to red...sometimes it stops for solid green. a very dim pale blank screen appears for about 30 secs along with the fans starting up....i have 216v on the ps output...i havnt checked any other volts because i have no circuit diagram. the ps on the face of it looks ok but im not really sure.any ideas out there...
Hi Ronnieboy1,
Have a look at this site for service manual
http://www.scribd.com/doc/12992883/PANASONIC-PLASMA-TH42PZ700UA
....and this one for training info preview
http://www.scribd.com/doc/88855992/Th42pz700a-Training
hope this helps,
Rotarymaker
thanks very much...with this information I can now sort this fault out.....as soon as its repaired I will tell the group in case anybody gets the same problem. regards brian.
Not a problem Ronnieboy1, I'm glad it was of some help to you. Hope you get TV up and running,
looking forward to hearing your successful fault find!
best regards,
Rotarymaker
ronnieboy 1
the fault with this plasma tv was no 15v on the power supply.....the actual fault was open circuit resistor 330k.
