Parabolic antenna
sniper007
I want to know why have this parabolic antenna which stands near TV production house wind around cable over the surface ?
Regards,
Sniper
Regards,
Sniper
Just a guess, but I bet the dish is made of some non-conductive material such as fiberglass and therefore the dish requires the 'wind around cable' to act as the actual reflector material for the RF signal.
Lefty
My best guess is that the cable is what is known as a "trace heater" which is used in winter to prevent a layer of snow and ice forming on the surface of the parabola.
Snow and ice would severely affect the performance of the antenna.
I'm going to go with the 'heater' idea. A spiral wound conductor like that doesn't make sense for a reflector, a fiberglass dish would use a metal screen as a framework which would act as the reflector. And not even as a signal attenuator the snow and ice may easily cause the dish to collapse from weight depending on it's orientation an environment. We have had multiple 'ice' storms in our area in the last 15 years which have thinned down the weak tree and inadequately supported dish population quiet a bit =) I'm guessing this is in a location where cooling/heating cycles lend themselves to ice buildup.
Yes, I think your guess is better then mine. Being from sunny California winterizing equipment is something that doesn't always come to mind :p
Hi Sniper007,
take a closer look at the antenna. If it's heated there should be at least two cables be connected to it.
Although the dish might be looking not be made of conductive material it's probably a weather protective coating of the wire mesh of the dish.
In Thailand Ip-Star (communication satellite) dishes look like being made of plastic.
Hans
Now I look again at the photo, there are two spirals, one which goes all the way to the outer edge of the dish, and another which only goes about on third of the way out.
If you look carefully at the centre of the dish you will see what appears to be a black "wire" coming from under the silver sticky tape. These two wires (the heater cable) appear to join together and then one cable, presumably the power feed, drops vertically from the centre of the dish and is then tywrapped on to the support structure.
Snow in my location is annual and probably yours guessing about heater is correct.
Tnx all alot
Sniper
