archiecles123
can i parallel 4 output pins of uln2803 so that it can have current greater than 1A? thanks
The ULN2803A is a high-voltage, high-current
Darlington transistor array. The device consists of
eight npn Darlington pairs that feature
high-voltage outputs with common-cathode
clamp diodes for switching inductive loads. The
collector-current rating of each Darlington pair is
500 mA. The Darlington pairs may be connected
in parallel for higher current capability.
Total substrate-terminal current . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . −2.5 A
The maximum current per IC is 2.5 amps!
