Hello!
I'm building a Z80 minicomputer on wire-wrapped perforated board. I just finished wiring the address bus and data bus pins to input pins on buffers (A 2-way buffer for the data bus). I connected all unused inputs to +5v, and created a single-step clock. My voltmeter shows that the power supply is +5.01v.
At this point I powered on the computer, took it out of reset, and stepped a couple times, and checked the output of the pins with the voltmeter. They seem odd.
I would normally assume that the address bus value would be incrementing, as the input from the data bus is 0x00000000 (NOP). However, the output of the pins are usually inconclusive, being some weird value between 0v and 5v (usually 1 or 3 something volts). The values of unused outputs and the address bus output doesn't change, whether in reset or not.
Also, the 5v regulator and the center of the Z80 gets really hot after a couple minutes. If I press my finger on the center of the Z80, I can only hold it there for 10 seconds because it is so hot.
Is all of this normal, or is something wrong? If you'd like, I can send pictures of the front/back of the circuit, or I can find the output of every pin and list them.
The schematics are Donn Stewart's Z80 computer. I currently have wired up everything in the following pages:
And:
I also made a little change to the active pin on the Address LO chip, and attached that to a SPSD toggle switch, with it being connected to ground when off. This will allow me to take manual control of the lower 8 bits of the address line when I want to manually reprogram the RAM. Currently it will be 0v, like the schematics say. Also, the clock input on the Z80 is directly attached to the step button.
It seems like it is really wrong, and the heat doesn't seem normal.
Any insight into this would be great!![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Thanks,
Drew
And:
Images Copyright Donn Stewart
Thanks,
Drew
