PCB layout help
mrhectic
Hi there.
I was hoping someone could check to see if my PCB layout is ok. I'd like to be sure it ready to be made before i commit with my cash.
im a complete novice, and managed to do this with a bit of help from a friend. I laid all the tracks down myself so im not 100% certain it correct.
I've attatched the file to this post. If anyone can check it for me, i would be truely greatful!
Thanks!
  • TARIQUR_BASE_V8_v70 (2).zip
hi. thanks for the advice. Is that the only real issue?
I decided to make them that thin because of the legs on the microcontroller and audio chip . if i make the tracks larger, they will come in contact with the neibouring legs?
the ones near the microcontroller and audio chip should be ok. By the way, are you going to professionally manufacture it? You can ask them to check your board with their minimum allowable track :D
