there is nothing posted :?: :?:here is the schematic
baftab said:i found its data sheet
it is a Qusai AB type amplifier
will this circuit work?
i'll start working on it from tomorrow
can u explain its working a bit?
the 2 capacitors in parallel..what is it called?
Hee, hee. :lol: What 24k resistor? :lol:Nigel Goodwin said:Why is the very bottom resistor 24K?.
baftab said:ok..i am making a dual power supply for it too
it'll earn me more marks
i made a dual power supply before....but..it is 15 to -15 volts
any way of improving it so tht it could work from +25 to -25?
Its datasheet shows how much lower its output power will be with a lower supply voltage.baftab said:ok..i am making a dual power supply for it too
if the output v is less than 25 say...23 or 22..will by power amp work?
Its datasheet shows how much higher its power supply current will be and how much more its output power and heating will be.should i make a supply with a wider range? say till + - 35?
I don't know since you are just copying the circuit.how can this one be improvised?
You must plan the entire design of a power supply, not just its voltage.using a higher rating transformer?
baftab said:check the schematic i attached...is it fine???
baftab said:i made the power supply and it works +35 to -35
