Phase control dimming
Adam
I am trying to do phase control dimming using a 16f627 on 4mhz internal osc, using pic basic
**broken link removed** , but I used two of the 22k resisters in series becuase of the higher voltage in the uk
@ device INTRC_OSC_NOCLKOUT
cmcon = 7
level var byte
stage var byte
level = 128
sync:
if portb.1 = 0 then loop
goto sync
Loop:
if portb.1 = 1 then zero
goto loop
zero:
pauseus 100
for stage = 0 to 255
if stage = level then
  High PORTB.0
  pauseus 35
  low PORTB.0
else
  pauseus 35
endif
next stage
goto Loop
end
I know that by the time it finishes the loops that the full half cycle hasn't ended, but it needs time to detect the next zero crossing (pulse 100u before crossing), also triggering in last 10% wont result in any light output.
Now my problem is there is a fast flicker on the light, far too fast to count them, but its noticeable (sort of like when a computer monitor is not on fast enough refresh rate)
I haven't got any kind of filtering, but someone says that when they did phase control dimming with a PIC, it didn't flicker when it had no filtering (its only dimming a 60w desklamp)
The switching part is a moc3020 with 8 amp triac
