Hi, I am hoping to detect the phase difference from a 433.92MHz carrier signal detected at two antennas, where one antenna is about a 1/4 wavelength further from the transmitter than the other.
The circuit looks as follows. I use PLLs to ensure phase lock on the carrier and pass the 2 signals to a phase detector:
I hope you can understand my circuit diagram. A second Bandpass filter after the BJT Amps would double the 6dB of the first to 12dB, so I will probably put those in each line aswell.
My questions are:
1) Do I really need the PLLs? Can I just put the antenna signals into the Phase difference detector without phase lock, or do I really need the VCO (powered) output?
2) If PLLs needed, what ICs do you recommend? Do I need special PLLs capable of locking onto a 433.92MHz signal? Or can I somehow use standard 4046/LM565??
3) What IC for final phase comparator? Anything special required?
I hope you can answer my questions!! If you can, then you have probably guessed that the circuit is designed to detect which antenna is closest to the transmitter source, within a wavelength as per diagram:
Antennae are about a foot apart, transmitter is off in the distance.
HOPE YOU CAN HELP!!!!!
(Antenna 1) (Antenna 2)
(JFET AMP 1) (JFET AMP 2)
(~433.92 MHz Bandpass 1) (~433.92 MHz Bandpass 2)
(BJT AMP 1) (BJT AMP 2)
(PLL1) (PLL2)
(PHASE COMP)--------------------------------|
OUTPUT
My questions are:
Antenna1
-------------------------------//------------------------- Transmitter
Antenna2
