Philips 55pos9002 Ambilight - Not turning on | Red light blinking 4-41 times
nununs
Hello :)
I have a defective Philips 55pos9002 Ambilight here. It won't turn on.
I was wondering if anyone else has had the same issue, and how did you manage to fix it.
What happens:
When I plug the power cord in, without even touching the remote control, the led light starts blinking extremely fast.
Using the remote control doesn't turn the TV on. Actually nothing happens.
I counted the led blinking lights (by shooting a video on slow motion, otherwise it's so fast that it's simply impossible to count) - There are two sequences: 4 initial blinks, followed by a short pause, followed by 41 blinks.
- I've attached the video as a zip file with this post, you can check it out.
I looked up the Service Manual for this TV, in order to find out what this blinking light error code means, but I can't seem to figure it out.
There's apparently two "Layers" - Layer 1, and Layer 2 - so I'm assuming the first sequence of the led blinking corresponds to Layer 1 error codes, while the second part of the led blinking corresponds to the Layer 2 error codes.
However, if that is correct ,there's a match for the first sequence of "4" in Layer 1, but there isn't even an error code for "41" on Layer 2.
Here's a screenshot from the manual:
I've attached the Service Manual with this post, for anyone interested.
Would appreciate any help.
Cheers
  • Philips_TPM17.1E_LA.pdf
  • slowmo-philips_1.zip
