Hi there,
Recently I acquired a Philips MCD-139; this is a 2.1 DVD / micro system.
The trouble is, I do not have the DVD/Micro system component. What I do have is the Subwoofer, Amplifier (integrated into the Left channel) and the Right speaker.
There is a 9-pin DIN connector which would (under normal circumstances) connect the Micro unit to the amplifier/speakers. I figured that all this cable would do is:
1. Provide the input sound
2. Control the volume
Step 1:
I started investigating which pin goes where.
As per the photos above, I created the following diagram to easily track where each goes.
Pin 1 (Surround) - A + D (Common / Ground)
Pin 2 - E + F
Pin 3 - E + F
Pin 4 - H
Pin 5 - A + D
Pin 6 - G (Sub?)
Pin 7 - A + D
Pin 8 - B (Right?)
Pin 9 - C (Left?)
Connectors E & F have 5v coming down them when the power is plugged in.
Any advice / suggestion as to where to go from here?
Thank you in advance![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Step 1:
Pin 2 - E + F
Pin 3 - E + F
Pin 4 - H
Pin 5 - A + D
Pin 6 - G (Sub?)
Pin 7 - A + D
Pin 8 - B (Right?)
Pin 9 - C (Left?)
