well there would be many output each with its own high and low intensity, therefore to I need detector that could in itself turn on only specific intensity.Can't you use a single detector and measure its output to distinguish between the lights?
I need intensity detectors without electronic circuitryNot sure what your application is, but you can put bandpass filters on the source e.g.https://www.edmundoptics.com/optics...rs/visible-bandpass-interference-filters/3429 and as long as your detector detects that range, your good to go.
It is hard to envision a photodiode-based intensity detector that works completely without electronic circuitry. The mere fact it is a photodiode implies some electronics.I need intensity detectors without electronic circuitry
so this kind of thing doesn't exist, alright thanks for the help.
Are there any photo diode in market that is able to detect only a specific intensity of light, of specific frequency range.
for ex- in the range of 2-3 LUX beyond and above which they just cut off.
