PIC 12F675 TO PIC 16F676 CODE CONVERSION
sahu
Any body help me for CODE CONVERSION PIC 12F675 TO PIC 16F676
// Global includes
#include <htc.h>
__CONFIG(FOSC_INTRCIO & WDTE_OFF & PWRTE_OFF & MCLRE_OFF & CP_OFF & CPD_OFF);
#define LED        GPIObits.GPIO5                // IR port status indicator LED defination
#define RELAY1        GPIObits.GPIO0                // RELAYS PORT definations
#define RELAY2        GPIObits.GPIO1
#define RELAY3        GPIObits.GPIO2
#define RELAY4        GPIObits.GPIO4
#define IRSENSOR GPIObits.GPIO3                // IR PORT defination
//#define TICKSPERMS  1004      // tick in a milli second
#define TICKS11ms        11044              // ticks in 11ms
#define TICKS5o5ms        5522                // ticks in 5.5ms
#define TICKS2o3ms        2309                // ticks in 2.3ms
#define TICKS3ms          3012                // ticks in 3sm
#define TICKS0o2ms        200                        // ticks in 0.2ms
#define TICKS8ms        8032                // Tick
unsigned int TIMEOUT  =  TICKS11ms;              // the pulse should occur before this time excede Otherwise it is an error
unsigned int PREPULSE = TICKS8ms;                        // the interrupt should occur after this time Otherwise it is an error
static unsigned short long timer;                        // varible to keep track of long timeouts  ( it can also be int if you want to save flash memory for some other purpose  )
static unsigned char dataready;                                // varible to use as flag when data is completly received and  ready it is 1 else 0
static  unsigned char necpoj=0;                                          /* (necpoj=NEC position )this varible is used to keep track of the edges of the input singal
        as decoding of the singal is done by a state machine
        so this varible acutalley sotores what state we currently are
        and total bits 32 and 2 leading pulse */
static unsigned char address=0,notaddress=0;        // these varible are used to store received address
static unsigned char command=0,notcommand=0;        // these varible are used to store received address
void interruptOnChangeIsr(void);                                  // interrupt service routine for interrupt on change of input port for IR sensor of mcu
void timerInterruptIsr(void);                                        // interrupt service rouine for timer0
void interrupt t0intr(void)
        if(INTCONbits.T0IF)                                                        // check the timer0 over flow interrupt flag
        timerInterruptIsr();                                                // timer0 overflow interrupt has been occur call the isr
        INTCONbits.T0IF =0;                                                        // clear the timer0 interrupt flag
        else if (INTCONbits.GPIF)                                        // check the interrupt on change flag
                LED=1;        // to blink the LED when IR signal is received
                interruptOnChangeIsr();                                        // interrupt on change has been detected call the isr
                INTCONbits.GPIF =0;                                                // clear the interrupt on chage flag
                LED=0;        // to blink the LED when IR signal is received
/* THE main source code Start here*/
void main()
    CMCON=0x7;                                // disable the comparator
    ANSEL=0x00;                                // all pin are Digital
    TRISIO=0x8;                          // Only GP2 is set to input rest are out
        TMR0 = 0;                                // clar the timer
        OPTION_REG = 0x88;                //pullups are disabled
                                                        //timer0 clock source is internal
                                                        //timer0 perscaller is 1:1 (disabled "assigned to WDT")
        IOC = 0x8;                          //interrupt on change is only to the GPIO3
        INTCONbits.T0IE = 1;        // Timer0 overflow interrupt enable
        INTCONbits.T0IF = 0;    // clar the timer0 intrrupt flags
        INTCONbits.GPIE = 1;        // external interrupt on GPIO3 pin(4) is enabled
        INTCONbits.GPIF = 0;        // clear the external interrrupt flag
        INTCONbits.PEIE = 1;    // peripheral intrrupt enable
        INTCONbits.GIE = 1;    // GLOBL interrupt enable
        EEADR = 0x00;                        // load the state of port from EEPROM
        EECON1bits.RD = 1;                // Start reding EEPORM
        GPIO = EEDATA;                        // LOAD The readed data form EEPORM to GPIO
        while(1)                              // wait forever for  the data received and ready
        if(dataready)                        // data is received and ready to be procssed
                // key1  0x50        to        Toggle relay 1        // these are command of the IR remote control which i have
                // key2  0xD8        to        Toggle relay 2
                // key3  0xF8        to        Toggle relay 3
                // key4  0x30        to        Toggle relay 4
                // key5  0xB0        to        Turn off all the relays
                switch(command)        // swich on
                case 0x50: RELAY1 = !RELAY1;                //Toggle relay 1
                                  break;
                case 0xD8: RELAY2 = !RELAY2;                //Toggle relay 2
                                  break;
                case 0xF8: RELAY3 = !RELAY3;                //Toggle relay 3
                                  break;
                case 0x30: RELAY4 = !RELAY4;                //Toggle relay 4
                                  break;
                case 0xB0: RELAY1 = 0;                                //Turn off all the relay
                                  RELAY2 = 0;
                                  RELAY3 = 0;
                                  RELAY4 = 0;
                                  break;
                default :
                                        break;
                EEADR = 0x00;                        //Write PORT status to EEPROM
                EEDATA = GPIO;                        // load the current status of GPIO to EEPROM write register
                EECON1bits.WREN = 1;          // Enable EEPROM write
                INTCONbits.GIE = 0;                //1        disable the interrupts as it may currupt the EEPROM data
                EECON2 = 0x55;                        //2
                EECON2 = 0xAA;                        //3        (1,2,3) require sequence
                EECON1bits.WR = 1;          // satart writing
                INTCONbits.GIE = 1;          // Enable the interrupts
                dataready=0;                        // data has been processed so clear the dataready flag
unsigned short long tdiff;
unsigned char pin;
static unsigned long rxbuffer;
tdiff = ((timer<<8)+TMR0) ;    // calculate how much time has been passed since last interrupt
        // the time shold be less then time out and greater than PREPULSE
pin = IRSENSOR;                                        // store the current status of Sensor
TMR0 = 0;                                                // reset the timer0 to measure the next edge(interrupt) of input
timer = 0;                                                // reset the timer varible to
/* state machine is started here and it totally managed and keeps track of its states using the varible necpoj
here are the details of necpoj ( NEC position ) varible
if
necpoj == 1      we just detected the first edge of the input singal it may also mean(if interrupt is not false) that the 9ms leading pulse started
                                  after the first edge THE next pulse is expected to arrive around 9ms so the TIMEOUT is set to 11ms and PREPULSE is set to 8ms
necpoj == 2          we just detected the second edge of the input signal and we finished the 9ms leding pulse and now 4.5ms space started
                                  after the second edge the next pulse is expected to arrive around 4.5ms so TIMEOUT is set to 5.5ms and PREPULSE is 3ms
necpoj == 3            we just detected the third edge of the input singal and we finished 4.5ms space and addres lsb is now started
                                  after the third edge the next pulse is expected to arrive around 562.5us so TIMEOUT is set to 2.3ms and PREPULSE is 0.2ms (timeout can be much less at this state but to do this i have to add one more if else statemetnt)
necpoj == 4          we just decected the forth edge and the 562.5 us burt of LSB of address has ended now a little space for '0'562.5us  or for '1' 1.6875ms
                                  after the forth edge the next pulse is expected to arrive for '0' around 562.5us  and for '1' 1.675ms so TIMEOUT is set to 2.3ms and PREPULSE is 0.2ms
necpoj ==5 to 66  data pulse keep comming
                                        TIMOUT and PREPLUSE remain same as above.
necpoj ==67                  we just fined the command inverse MSB space not the final 562.5us burst has stated  so we fined the receiveing
                                  now we will check the address and command for being correct
if ((tdiff>PREPULSE) && (tdiff<TIMEOUT) )                // the edge (interrupt) occurrence time should be less then the TIMOUT and greater then PREPULESE else it is an fake singal
{        // At the very first edge (necpoj==0)  this conditon will always false and the false block of this if will bring the state machine (necpoj) to position 1(position 1 means 9ms leading pulse has started now we have to wait for 4.5ms start pulse to occur)
        if(necpoj==1 || necpoj==2)                                        // when we are hear it means 9ms leding pulse has ended and now we are necpoj=1 or necpoj=2
                        if((pin==1) && (necpoj==1))
                        necpoj++;
                        TIMEOUT        = TICKS5o5ms;                          // timeout for 3rd pulse 5.5ms
                        PREPULSE          = TICKS3ms;                                // PREPULSE for 3rd pulse 3ms
                        else if((pin==0)&& (necpoj ==2))
                        necpoj++;
                        TIMEOUT        = TICKS2o3ms;                          // now data starts so timeout is 2.3ms
                        PREPULSE          = TICKS0o2ms;
                        else        // this block handle the conditon if any error occur after the completing the pre pulses
                        necpoj = 0;                                                        //reset the state machine
        else if(necpoj>2)                                                        //now we are picking the data
                        necpoj++;                                                        //necpoj sill inrement on every edge
                                if(necpoj&0x01)                                        // here we check the if necpoj is an odd number because when necpoj goes greater then 3 then
        //necpoj will always be and odd value when a single bit tranmission is over
                                        rxbuffer=rxbuffer<<1;                //shift the buffer
                                        if(tdiff>1250)                                //we are here means we just recevied the edge of finished tranmission of a bit
        // so if last edge was more than 1.24 ms then the bit which is just over is one else it is zero
                                        rxbuffer = rxbuffer | 0x1;
                                //        GPIObits.GPIO5 = !GPIObits.GPIO5;
                                        else
                                        rxbuffer = rxbuffer |0x0;
                            //        GPIObits.GPIO4 = !GPIObits.GPIO4;
                        if(necpoj >66)                                                // we have reached (Leading pulse 2 +address 16+~address16+ command 16+ ~command 16+ last final burst first edge 1)=67th edge of the message frame means the date tranmission is now over
                        address        = (rxbuffer>>24)& 0xFF;                        //extract the data from the buffer
                        notaddress        = (rxbuffer>>16)& 0xFF;
                        command        = (rxbuffer>>8)        & 0xFF;
                        notcommand        = (rxbuffer)        & 0xFF;
                        rxbuffer=0;        //clear the buffer
                                        if((!(address & notaddress)) && (!(command & notcommand)))                // check weather the received data is vaild or not
                                        dataready =1;
                                        else
                                        dataready=0;
                        TIMEOUT        =          TICKS11ms;                                        // weather we received the vaild data or not we have to reset the state machine
                        necpoj=0;
        else
        TIMEOUT        =        TICKS11ms;                                                        // some error occured reset state machine
else
        if(pin==0)                                //we are here means that after a longtimeout or PREPULSE we just detect a pulse which may be the start of 9ms pulse
        necpoj = 1;                                // yes it could be the start of 9ms pulse
        else
        necpoj = 0;                                // no it's not start of 9ms pulse
        address        = 0xFF;
        notaddress        = 0xFF;
        command        = 0xFF;
        notcommand        = 0xFF;
        dataready        = 0x000;
        TIMEOUT =  TICKS11ms;                //default timing
if(timer<0xFFFF)                        // this code is to increment the variable timer's value on every over flow but this if conditon will prevent this variable form rollover when a long timeout occurs
timer++;
You need to tell us which pins you intend to use for the relays LED's etc....
I have changed it to work solely on port A
C:
// Global includes
#include <htc.h>
#define LED        PORTAbits.RA5                // IR port status indicator LED defination
#define RELAY1     PORTAbits.RA0                // RELAYS PORT definations
#define RELAY2     PORTAbits.RA1
#define RELAY3     PORTAbits.RA2
#define RELAY4     PORTAbits.RA4
#define IRSENSOR   PORTAbits.RA3                // IR PORT defination
        else if (INTCONbits.RAIF)                 // check the interrupt on change flag
                INTCONbits.RAIF =0;              // clear the interrupt on chage flag
void main()
    TRISA=0x8;                          // Only GP2 is set to input rest are out
        INTCONbits.RAIE = 1;        // external interrupt on GPIO3 pin(4) is enabled
        INTCONbits.RAIF = 0;        // clear the external interrrupt flag
        PORTA = EEDATA;                        // LOAD The readed data form EEPORM to GPIO
                                  break;
                                  break;
                                  break;
                                  break;
                                  RELAY2 = 0;
                                  RELAY3 = 0;
                                  RELAY4 = 0;
                                  break;
                default :
                                        break;
                EEDATA = PORTA;                        // load the current status of GPIO to EEPROM write register
                EECON2 = 0x55;                        //2
unsigned char pin;
if
                        necpoj++;
                        necpoj++;
                                        else
                                        dataready =1;
                                        else
                                        dataready=0;
                        necpoj=0;
        else
else
        else
        address        = 0xFF;
        notaddress        = 0xFF;
        command        = 0xFF;
        notcommand        = 0xFF;
        dataready        = 0x000;
timer++;
C:
// Global includes
#include <htc.h>
void main()
                                  break;
                                  break;
                                  break;
                                  break;
                                  RELAY2 = 0;
                                  RELAY3 = 0;
                                  RELAY4 = 0;
                                  break;
                default :
                                        break;
                EECON2 = 0x55;                        //2
unsigned char pin;
if
                        necpoj++;
                        necpoj++;
                                        else
                                        dataready =1;
                                        else
                                        dataready=0;
                        necpoj=0;
        else
else
        else
        address        = 0xFF;
        notaddress        = 0xFF;
        command        = 0xFF;
        notcommand        = 0xFF;
        dataready        = 0x000;
timer++;
I WANT UES rest ports as
#define LED PORTAbits.RA0 // IR port status indicator LED defination we use here BZR
#define RELAY1 PORTAbits.RA1 //Drive output 1{pin.11}
#define RELAY2 PORTAbits.RA2 //Drive output 2{pin.10}
#define RELAY3 PORTCbits.RC0 //Drive output 3{pin.09}
#define RELAY4 PORTCbits.RC1 //Drive output 4{pin.08}
#define RELAY5 PORTCbits.RC2 //Drive output 5{pin.12}
#define RELAY6 PORTCbits.RC3 //Drive output 6{pin.05}
#define RELAY7 PORTCbits.RC4 //Drive output 7{pin.06}
#define RELAY8 PORTCbits.RC5 //Drive output 8{pin.07}
#define RELAY9 PORTAbits.RA4 //Drive output 9{pin.03}
#define RELAY10 PORTAbits.RA5 //Drive output 10{pin.02}
#define IRSENSOR PORTAbits.RA3 // IR PORT defination IR SENSOR input
so modified as
    TRISA=0x8;                          // Only PORTA3 is set to input rest are out
    TRISC=0x0;                          // PORTC is set  are out
  PORTA = EEDATA;  // LOAD The readed data form EEPORM to PORTA
PORTC = EEDATA;  // LOAD The readed data form EEPORM to PORTC
C:
// Global includes
#include <htc.h>
void main()
                                  break;
                                  break;
                                  break;
                                  break;
                                  RELAY2 = 0;
                                  RELAY3 = 0;
                                  RELAY4 = 0;
                                  break;
                default :
                                        break;
                EECON2 = 0x55;                        //2
unsigned char pin;
if
                        necpoj++;
                        necpoj++;
                                        else
                                        dataready =1;
                                        else
                                        dataready=0;
                        necpoj=0;
        else
else
        else
        address        = 0xFF;
        notaddress        = 0xFF;
        command        = 0xFF;
        notcommand        = 0xFF;
        dataready        = 0x000;
timer++;
in the code where "define ADDRESS" value (address for the Data Framing) ?
pl explne it
Whoah! This was a while ago..
pl explne it
This means nothing to me... I can't explain it as I don't know to what you are referring to.
each remote have 1 ADDRESS value & many command value .
so i tell this ADDRESS value explanation .
I would need a link to the remote datasheet. The "adress" is for talking to the right device.​
yes sir , I'm telling where in the code "address value " define .
like
case 0x50:
defineed as command value .
The address and complemented address are stored in these variables when receiving:
The code ignores the address bits, other than to check for valid complement, so will respond to any JVC remote handset, providing the command byte is recognised.
IR hand set.. Oh! I didn't know what we were talking about!
its means need only valid byte of NEC commands .
i want use this remote .
so how can red its commands byte ?
Command byte is store in variable "command"
static unsigned char command=0,notcommand=0;        // these varible are used to store received command
I have corrected the comment, which was wrong.
EDIT - Correction - Since this PIC has no UART and no spare 8-bit port, I can't think of any easy way to show the contents of byte "command". I do not see how I can help further.
Send the byte "command" to UART or a spare port with LEDs connected to display the command byte as each command is received.
pl give 1 little exp.
Please do not write in "text speak", it makes me angry, and makes you even harder to understand.
I think I gave you bad advice above. To find out what signals your remote control sends, a logic analyser is a good tool to use.
Do you have a logic analyser? .... Or a genuine PICkit2 with working logic analyser utility?
.... or a Digital Storage Oscilloscope?
yes i have PICkit 2 v2.61 programmer with logic analyser utility.
Great! you can see the transmit signal with PICkit2.
Connect your 3-pin IR receiver chip to input 3 of the Logic Analyser (and supply 5 volts to receiver too)
Use input 3, since the other inputs have a pull-down resistor.
You may need a 10k ohm pull-up resistor on the IR receiver output, but probably not.
Set logic analyser to trigger on falling edge of input 3 and press a remote button.
Spot the header bit and decode the ones and noughts by eye to work out address and command.
Repeat for each button on the remote.
You may need to experiment a bit to get best sampling rate to make the received waveform readable.
Good luck
Good luck
those connection are as
