PIC 16F627A Programming problem
mas
I am using the chip pic 16f627a
setting PORTA to inputs & PORTB to outputs >>
bsf STATUS,PR0
movlw 0xFF
movwf TRISA
movlw 0x00
movwf TRISB
bcf STATUS,RP0
giving a high input to PORTA,0 >>
bsf PORTA,0
btfsc PORTA,0
I used the btfsc(bit test skip if zero instruction) .. and the tested pin is set to '1' .. so the program shoudn't skip the ****** line
My problem is that the program skips the ****** instruction ,, and goes to the $$$$$$ instruction .. although the tested pin is set to high '1'
If any one knows where is the fault .. I am so gratefull :)
The pins of PORTA are configured as inputs.
Try this:
movlw 0x00
movwf TRISA
and see what happens.
Try this:
movlw 0x00
movwf TRISA
Do you mean that if the pin is set to input .. Then I can't assign it to high or low ??
If I'm not mistaken, pins set as inputs have their bits set according to the incoming voltage level with VDD=Set and VSS=Unset. Don't forget to turn off the comparators to enable digital input.
If you want to set or clear a bit of PORTA in software, that pin is an output by definition.
When a pin is configured as an input you can read its value, which depends on the applied voltage, as TekNoir said.
I guess you're trying to emulate a switch. If so, you configured PORTA correctly, but the last bsf instruction makes no sense.
yes, I was trying to simulate
I will use a hardware circuit to test the program instead of the simulator
Thanks a lot guys :)
It is possible to apply a 'stimulus' with the simulator, but it's simple to add a switch with a pull-up resistor (external or internal) to your circuit.
Have fun :)
