the circuit is connectes in a 4 bit basis and
the 4 upper bit DB4
B7 (pin11 to pin14), of the LCD are connected to
the 4 upper bit RB4:RB7 (pin10 to pin13) of the PIC 16F628
A2= R/W, A1=R/S, A0=E
problem: the program instead to write "control-12" write only blanks.
;writing "control 12" on the LCD screen
list p=16F628A
#include <p16F628A.inc>
errorlevel -302, -207
__CONFIG _CP_OFF & _DATA_CP_OFF & _LVP_OFF & _BOREN_ON & _MCLRE_ON & _WDT_OFF & _PWRTE_ON & _XT_OSC
#define status STATUS
#define option_reg OPTION_REG
#define intcon INTCON
#define Banco0 bcf status,5
#define Banco1 bsf status,5
#define portb PORTB
#define TrisB TRISB
#define Trisb TRISB
#define trisb TRISB
#define Trisa TRISA
#define tmr1h TMR1H
#define tmr1l TMR1L
#define tmr1on bsf T1CON,0
#define tmr1off bcf T1CON,0
#define pir1 PIR1
#define t1con T1CON
#define tmr1ie TMR1IE
#define porta PORTA
#define trisa TRISA
#define vrcon VRCON
#define cmcon CMCON
no equ 0x26
no2 equ 0x28
org 0x0000 ; para...
movlw 0x07 ; cerrar....
movwf cmcon ; el comparador
definiciones:
Banco1
clrf trisb
clrf trisa
clrf no
Banco0
;.....................arranque del Lcd
step1: call delay ;must be 15 mseg
step2: movlw 0x30 ;B'00110000';must be 4.1mseg, function set
call iniloop
step3: movlw 0x30 ;B'00110000';must be 100useg
call iniloop
step4: movlw 0x30 ;B'00110000', must be 100useg
call iniloop
step5: movlw 0x02 ;B'00100000', definition for 4bits address lines must be 100useg
call iniloop
step6: movlw 0x20 ;B'0010',function set=4bits must be 53useg
call iniloop
step6b: movlw 0x80 ;B'1000', , 2lines, 5x7
call iniloop
step7: movlw 0x00 ;B='0000' display on/off
call iniloop
step7b: movlw 0x80 ;B'1000', , display, cursor & blinking= off
call iniloop
step8: movlw 0x00 ;B'0000', , clear display
call iniloop
step8b: movlw 0x10 ;B'0001', , clear display
call iniloop
step9: movlw 0x00 ;B'0000', ,entry mode set
call iniloop
step9b: movlw 0x60 ;B'0110', , increment cursor, no display shift
call iniloop
;(step 10)....................initializations ends
step11: movlw 0x00 ;B'0000', , turning on the display
call iniloop
step11b: movlw 0x60 ;B'1110', , display=on, cursor= on, blinking=off
call iniloop
goto programa
iniloop: movwf portb
;movlw 0x00 ;
;movwf porta ;r/s= 0, r/w=0
movlw 0x01
movwf porta ;e=1
call delay
movlw 0x00
movwf porta ;e=0
return
programa: movlw 0xC0 ;DD Ram= C0
call inst
movlw 0x10
call inst
programa2: movlw 0x44 ;C
call datos
movlw 0x33
call datos
movlw 0x44 ;O
call datos
movlw 0xFF
call datos
movlw 0x44 ;N
call datos
movlw 0xEE
call datos
movlw 0x55 ;T
call datos
movlw 0x44
call datos
movlw 0x55 ;R
call datos
movlw 0x22
call datos
movlw 0x44 ;O
call datos
movlw 0xFF
call datos
movlw 0x44 ;L
call datos
movlw 0xCC
call datos
movlw 0x22 ;-
call datos
movlw 0xDD
call datos
movlw 0x33 ;1
call datos
movlw 0x11
call datos
movlw 0x33 ;2
call datos
movlw 0x22
call datos
goto programa2
inst: movwf portb
;movlw 0x00 ;
;movwf porta ;r/w= 0, r/s=0,e=0
movlw 0x01
movwf porta ;e=1
call delay
movlw 0x00
movwf porta ;e=0
call delay
return
datos: movwf portb
;movlw 0x02 ;
;movwf porta ; r/w=0, r/s= 1, e=0; data, write
movlw 0x03
movwf porta ;e=1
call delay
movlw 0x02
movwf porta ;e=0
call delay
return
delay: bsf t1con,0 ;timer 1 on
loop: nop
btfss pir1,0 ;flag overflow tmr1 on?
goto loop
bcf pir1,0 ;switch off tmr1 flag
return
end
the 4 upper bit DB4
list p=16F628A
#define portb PORTB
#define TrisB TRISB
#define Trisb TRISB
#define trisb TRISB
#define Trisa TRISA
#define tmr1h TMR1H
#define tmr1l TMR1L
#define pir1 PIR1
#define t1con T1CON
#define porta PORTA
#define trisa TRISA
#define vrcon VRCON
#define cmcon CMCON
no equ 0x26
no2 equ 0x28
definiciones:
Banco1
clrf trisb
clrf trisa
clrf no
Banco0
call iniloop
call iniloop
call iniloop
call iniloop
call iniloop
call iniloop
call iniloop
call iniloop
call iniloop
call iniloop
call iniloop
call iniloop
call iniloop
call iniloop
goto programa
;movlw 0x00 ;
movlw 0x01
movwf porta ;e=1
call delay
movlw 0x00
movwf porta ;e=0
return
call inst
movlw 0x10
call inst
call datos
movlw 0x33
call datos
movlw 0x44 ;O
call datos
movlw 0xFF
call datos
movlw 0x44 ;N
call datos
movlw 0xEE
call datos
movlw 0x55 ;T
call datos
movlw 0x44
call datos
movlw 0x55 ;R
call datos
movlw 0x22
call datos
movlw 0x44 ;O
call datos
movlw 0xFF
call datos
movlw 0x44 ;L
call datos
movlw 0xCC
call datos
movlw 0x22 ;-
call datos
movlw 0xDD
call datos
movlw 0x33 ;1
call datos
movlw 0x11
call datos
movlw 0x33 ;2
call datos
movlw 0x22
call datos
goto programa2
inst: movwf portb
;movlw 0x00 ;
movlw 0x01
movwf porta ;e=1
call delay
movlw 0x00
movwf porta ;e=0
call delay
return
datos: movwf portb
;movlw 0x02 ;
movlw 0x03
movwf porta ;e=1
call delay
movlw 0x02
movwf porta ;e=0
call delay
return
loop: nop
goto loop
return
end
