PIC 16F628A comparator unused I/O pins
BobW
Active Member
It's not clear in the documentation that if you have the comparator config register set up to enable only one of the two comparators, whether the unused I/O pins can be used for regular digital I/O functions.
For example, if I set CMCON=0x05 then comparator 1 is disabled and comparator 2 is enabled. I would like to use RA0 and RA3 (otherwise assigned to comparator 1) as digital I/O. Is this possible?
If you look at page 64 figure you have to use 2 pins it shows how they are laid out. the rest can be I/o pins
Thanks. I had referred to page 64 of the data sheet, but it never states clearly that the unused comparator pins are available to be used as regular I/O. I also checked the PIC Mid-Range MCU Family Reference Manual, and couldn't find anything definitive there either. I realize it's logical to assume that the unused pins would be available, but I seem to recall making similar assumptions in the past which proved to be wrong.
Okay, after reading the data sheet one more time, I finally found what I'd been missing. Just in case others have had similar problems and are as unobservant as I am, I've attached an excerpt from the data sheet with the important parts outlined in red, for future reference.
Now I have another problem. I've configured the PIC to enable a single comparator (comparator 2) using mode 101, but for some reason the non-inverting input (aka, RA2/AN2/Vref) appears to be operating as an output. I've configured the TRISA register so that it is an input. I've configured the VRCON register to all zeroes to disable the Vref output. But that pin still comes up in a low impedance state, on power up randomly as 0v or +5v with enough power to drive an LED. I thought maybe I fried the chip, so I substituted another one, and it behaves the same way. I can't see anything in the docs that would affect this pin. Is there some other configuration register that I've overlooked?
Have some code??? The according to the datasheet, it would seem ... RA2 and RA1 should be inputs and C2 is the output!!! However!! Remember this is an opamp... RA2 and RA1 are a virtual ground!! You will see the same voltage on RA2 as RA1 if RA2 isn't connected....
Pause your code and make sure that TRISA is set correctly. It's easy to miss it if you get the bank switching wrong.
It may have been a MPLABX issue. After my last post, I noticed that the PICkit3 programmer started behaving strangely. So, I shut everything down and rebooted MPLABX. I downloaded the program to the PIC again, and gave it a quick run. It was too late at night to do any serious testing, but it appeared that the input problem might be fixed. I'll do more testing later and report back.
Well it turned out to be a simple problem, and now I have another item to add to my PIC gotcha list. Before I rearranged the I/O in order to use the comparator, I made a copy of the project so that I could return to it if the need arose. Then I modified the source code of the new project. However, I forgot to set the new project as the main project. So, whenever I made a change to the new source code, it was still assembling and downloading the code from the old project.
Yeah!! Been there before! Takes quite a while for the penny to drop... I'm glad you found it..
