mesamune80
Hi all,
i had figuring this thing since last week, but i still not manage to find out what is the cause of this problem.............i also using the button debouce to detect my button.
Below is the code:
ADCON1 = 7 '%10001000 'A4-7 analog RA3 +Vref RA2 -Vref
TRISA = %11111111
TRISB = %00000001
TRISC = %11100000
TRISD = %11100011
OPTION_REG.6 = 1 'RB0/INT edge triggered (rising edge)
OPTION_REG.7 = 1 'weak pull up disable.
INTCON = %10010000
'Button debouce routine
If PORTA.0 = 0 Then Goto press 'button debounce checking..
press:
Disable' disable all unmask interrup
While PORTA.0 = 1
delay = 20
WaitMs delay
Wend
While PORTA.0 = 0 And delay <> 0
delay = delay - 1
Wend
If delay <> 0 Then
Goto loop2
Else
Goto release
Endif
release:
Disable
While PORTA.0 = 0
delay = 20
WaitMs delay
Wend
While PORTA.0 = 1 And delay <> 0
delay = delay - 1
Wend
If delay <> 0 Then
Goto release
Else
Goto m1
Endif
m1:
High PORTC.5 'my solenoid output..
WaitMs 500
Enable 'enable all unmask interrupt
While PORTC.6 <> 0
dir1 = 1 'CW DOWN
High PORTC.0 'pulse port for m1
WaitMs 1
Low PORTC.0
WaitMs 1
'count1 = count1 + 1
Wend
On Interrupt "My ISR
If INTCON.INTF = 1 Then 'RB0 External interrupt flag bit=1 (external interrupt occured)
INTCON.INTF = 0
Goto init
'Goto loop
Endif
'INTCON = %10010000 'renable RB0 interrupt and all unmask interrupt.
Resume
____________________________________________________________________________
ok this is the problem i am facing now....![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
the RB0 interrupt automatically executed although the interrupt button is not press.....>.<"
so everytime the program come to enable it automatically go to interrupt service routine.Anyone know what is the cause of this?
Thanks for all your help and guidance.
Below is the code:
TRISA = %11111111
TRISB = %00000001
TRISC = %11100000
TRISD = %11100011
INTCON = %10010000
press:
While PORTA.0 = 1
delay = 20
WaitMs delay
Wend
delay = delay - 1
Wend
If delay <> 0 Then
Goto loop2
Else
Goto release
Endif
release:
Disable
While PORTA.0 = 0
delay = 20
WaitMs delay
Wend
delay = delay - 1
Wend
If delay <> 0 Then
Goto release
Else
Goto m1
Endif
m1:
WaitMs 500
While PORTC.6 <> 0
dir1 = 1 'CW DOWN
WaitMs 1
Low PORTC.0
WaitMs 1
Wend
INTCON.INTF = 0
Goto init
'Goto loop
Endif
Resume
