PIC 16F877A problems with the memory, programmer pickit 3
Daniel Rengifo
someone can help me with that, i need to know what is the problema and the solution because i haven´t could debugger my PIC.
i make everything right, I have the compiler PICKIT 3 and i use the USB port for programmer, but when i am going to write in the PIC, i get that message, i don't know why? HELP MEEEEE!!!! thanks.
Are you sure you have the ICSP circuitry connected peroperly? Could you show us your schematic and a photo of your setup? Having these might help us diagnose the problem.
Also, check your setup against this:
Regards,
Matt
That looks like a faulty wiring as DerStorm8 has pointed out, its obviously a common mistake, Check for any dry soldering and check every pin reach the PIC controller (continuity).
