pic and encoder
aduri
Hello,
I tried these 2 programs but they don't work very well.
They miss some pulses during the count.
Can anybody help me?
' * Project name: Rotary encoder
' * Description: Rotary encoder with interrupt
' * Test configuration:
'     board: My Board Aduri
'     MCU:             PIC16F877A
'     Oscillator:      HS, 20.000 MHz
'     Ingressi   :     A su RB4, B su RB1
'     SW:              mikroBasic v5.0 or higher
' * NOTES:
'     LCD su PORTD, trigger with CD4093
program Rotary_encoder
dim temp as byte
dim txt as string[3]
sub procedure interrupt     ' Interrupt service routine
  If PORTB.4 = 1 then
    else
      If PORTB.1 = 1 then
      temp = temp - 1
        else
      temp = temp + 1
      end if
  end if
delay_ms(25)                     'delay
INTCON.RBIF = 0             ' interrupt flag disable
end sub
main:
  LCD_init(PORTD)        'LCD on portD
  TRISB = %11111111      'PORTB.1 and .4 are inputs
  INTCON = %10001000     ' Enable interrupt on change
while 1=1            ' loop
delay_ms(100)
bytetostr(temp,txt)
 LCD_out(1,1,"Nr pulses:")
LCD_out(2,1,txt)
wend
end.
and the follow:
program encoder_A
'     MCU:             PIC16F877A
'     Dev.Board:       Myboard
'     Ext. Modules:    trigger with CD4093, Lcd_2x16
'PROGRAM TO DETERMINE DIRECTION OF QUADRATURE ENCODER
DIM PORTB_OLD AS BYTE
DIM PORTB_NEW AS BYTE
dim count as byte
'USING A 2 BIT (QUADRATURE SYSTEM) THIS IS THE RULE:
'LOW BIT OF OLD VALUE IS ALWAYS EQUAL TO HIGH BIT OF NEW VALUE
'IF MOVING CLOCKWISE
'LOW BIT OF OLD VALUE DOES NOT EQUAL HIGH BIT OF NEW VALUE
'IF MOVING COUNTERCLOCKWISE
main:
'TRISA = 0              'RA0 LED WILL INDICATE CW; RA1 LED WILL INDICATE CCW
TRISB = %00000011      'RB0 and RB1 Inputs
TRISC = 0
PORTA = 0
PORTB = 0
 LCD_init(PORTD)        'LCD su portD
 LCD_out(1,1,"Numero impulsi:")
 LCD_out(2,1,"Dir:")
PORTB_OLD = PORTB
my_direction:
PORTB_NEW = PORTB
IF PORTB_NEW XOR PORTB_OLD <> 0 THEN     'test for encoder change
   IF (PORTB_NEW >> 1) = (PORTB_OLD AND 1) THEN
      PORTC = 1        'CW DIRECTION
       LCD_out(2,6,"I")
       count = count-1
   ELSE
      PORTC = 0       'CCW DIRECTION
       count = count+1
       LCD_out(2,6,"A")
   END IF
END IF
 bytetostr(count,txt)
     LCD_out(1,18,txt)
PORTB_OLD = PORTB_NEW
GOTO my_direction
end.
I don't know if this is the only problem with your code, but you shouldn't have the 25 millisecond delay in your interrupt handler.
Mike
