PIC Basic code error can you help, probably very simple
lompa
im trying to create a variable PW but i get this error
what am i doing wrong
Its probably just the wording of the line.Look in the help section on creating symbols.
Different Basic compilers use differing syntax.
Symbol should be declared before the "main:" section. Also, you should declare "pw" before you use the symbol:
  dim pw as word
  symbol  B1 = pw
main:
Declare variable name
If you want to use variable name "PW", you must declare it first in PicBasic Pro version. In PicBasic STD version,we don't need to declare variable and we can use pre defined variables.
Please declare like that:
PW var bit
or
PW var byte :)
