Pic Basic Newbie
SwingeyP
I would normally struggle with assembler to do thsi but having found pic basic i though i'd struggle with that instead ;-)
A couple of questions :
First off what's wrong with this please
Symbol outpin = PORTB.0
Const uplimit = 200 'Set upper limit - max. 255, each step is 10uS
Const downlimit = 100 'Set lower limit - min. 0
Dim pulse As Byte
TRISB = 0xff
pulse = 128 'Set initial value to middle
For pulseup = pulse To uplimit 'move from middle to upper limit'
ServoOut outpin, pulseup
delayms 18
Next pulseup
loop:
For pulsedown = uplimit To downlimit
ServoOut outpin, pulsedown
delayms 18
Next pulsedown
For pulseup = downlimit To uplimit 'move from lower to upper limit'
delayms 18
Next pulseup
Goto loop
Secondly has anyone written a plugin for the OSHON simulator to show servo control?
Many thanks - Paul
I am not familiar with PicBasic, but looks good. Using TRISB = 0xff "normally" means to make PortB all inputs. Use TRISB = 0x00 to make them all outputs, or TRISB = 0xfe to make all inputs, except PortB.0 as an output.
oops - yeah its meant to be output.
I get the following error:
Error line 11: The running variable in For statement must be Byte or Word data type.
Any ideas anyone?
and the moral of the story is ..... Read the manual!
Different variations of pic basic etc ... and yes the for next variables needed to be dimensioned too. Makes sense really.
Thanks for your help.
Dim pulse As Byte
Dim pulseup As Byte
Dim pulsedown As Byte
TRISB = 0xff
WaitMs 18
Next pulseup
loop:
WaitMs 18
Next pulsedown
WaitMs 18
Next pulseup
Goto loop
I don't suppose anyone out there has a plugin for demoing servos ...?
Regards - Paul
