camerart
I'm trying to convert a piece of code written in PIC Basic to Oshonsoft basic, below:
I get most of it, apart from 'ABS' and e,g, the decimal point in 'Distance.15' and the numbers 13 and 15.
Any help appreciated.
Camerart.
Position VAR WORD
Target VAR WORD
Distance VAR WORD
Position = 1234
Main:
HSEROUT[13, "You're at position: ", DEC Position, 13]
HSEROUT["Enter new target: ",13]
HSERIN[DEC Target]
' Actual calculation starts here.
' When done the variable Distance contains the
' number of "ticks" to target in two's complement format.
Distance = Target - Position
IF Distance.15 = 0 THEN ' Distance is positive
If Distance > 1790 THEN
Distance = Distance - 3580
Endif
ENDIF
IF Distance.15 = 1 THEN ' Distance is negative
IF ABS Distance > 1790 THEN
Distance = Distance + 3580
ENDIF
ENDIF
' End of calculation, result now in Distance.
Done:
HSEROUT["CCW "]
ELSE
HSEROUT["CW "]
ENDIF
HSEROUT[DEC ABS Distance, " ticks.", 13]
Position = Target
Goto Main
Camerart.
Position VAR WORD
Target VAR WORD
Distance VAR WORD
Position = 1234
Main:
HSERIN[DEC Target]
Endif
ENDIF
ENDIF
ENDIF
Done:
HSEROUT["CCW "]
ELSE
HSEROUT["CW "]
ENDIF
Position = Target
Goto Main
