I designed a RGB moodlight with PIC 16F628. I am using TMR0 interrupt for PWM and Pin B1-B3 for output. I thought of using a Nokia Charger for power supply. I made the PCB with the female adapter for the same. After deploying the code PIC is not working as expected. If the logic is simple as
if PinA0 is high the turn Pin B1 high then it works fine but with 3channel PWM in place it gives out voltage from all the pins..![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
First I trusted Nokia charger so much that I suspected PIC itself, but then some how I checked Charger output it is 6.5-6.6V. (but it is rated at 5.35V and its SMPS).
So do you think (or have prior experience) applying 6.5V to a pic will destroy it or affect the working?
Or should I again check my code only?
