; Dallas Semiconductor PIC code
; This code will interface a PIC16F628 microcontroller to
; a DS2761 High-Precision Li+ Battery Monitor
; VCC
; \ Rpup
; 16F628 | DS2761
; RB1 (pin 7) ------------------------------ DQ (pin 7)
; List your processor here.
list p=16F628
; Include the processor header file here.
#include <p16F628.inc>
; Assign the PORTB with Constants
constant DQ=1 ; Use RB1 (pin7) for 1-Wire
; These constants are standard 1-Wire ROM commands
constant SRCHROM=0xF0
constant RDROM=0x33
constant MTCHROM=0x55
constant SKPROM=0xCC
; These constants are used throughout the code
cblock 0x20
IOBYTE
TMP0 ; Address 0x23
COUNT ; Keep track of bits
PICMSB ; Store the MSB
PICLSB ; Store the LSB
PDBYTE ; Presence Detect Pulse
endc
; Setup your configuration word by using __config.
; For the 16F628, the bits are:
; CP1,CP0,CP1,CP0,N/A, CPD, LVP, BODEN, MCLRE, FOSC2, PWRTE, WDTE, FOSC1, FOSC0
; CP1 and CP0 are the Code Protection bits
; CPD: is the Data Code Protection Bit
; LVP is the Low Voltage Programming Enable bit
; PWRTE is the power-up Timer enable bit
; WDTE is the Watchdog timer enable bit
; FOSC2, FOSC1 and FOSC0 are the oscillator selection bits.
; CP disabled, LVP disabled, BOD disabled, MCLR enabled, PWRT disabled, WDT disabled, INTRC I/O oscillator
; 11111100111000
__config 0x3F38
; Set the program origin for subsequent code.
org 0x00
GOTO SETUP
NOP
NOP
NOP
GOTO INTERRUPT ; PC 0x04...INTERRUPT VECTOR!
INTERRUPT:
SLEEP
; Option Register bits
; ____
; RBPU,INTEDG,TOCS,TOSE,PSA,PS2,PS1,PS0
; 7=PORTB Pullup Enable, 6=Interrupt Edge Select, 5=TMR0 Source,
; 4=TMR0 Source Edge, 3=Prescaler Assign, 2-0=Prescaler Rate Select
; 11010111
; PORTB pullups disabled,rising edge,internal,hightolow,TMR0,1:256
SETUP:
BCF STATUS,RP1
BSF STATUS,RP0 ; Select Bank 1 of data memory
MOVLW 0xD7
MOVWF OPTION_REG
BCF STATUS,RP0 ; Select Bank 0 of data memory
BCF INTCON,7 ; Disable all interrupts.
GOTO START
; Include the 1-Wire communication routines and macros
#INCLUDE 1w_16f6x.inc
START:
GET_TEMP:
CALL OW_RESET ; Send Reset Pulse and read for Presence Detect Pulse
BTFSS PDBYTE,0 ; 1 = Presence Detect Detected
GOTO NOPDPULSE
MOVLW SKPROM
CALL DSTXBYTE ; Send Skip ROM Command (0xCC)
MOVLW 0x69
CALL DSTXBYTE ; Send Read Data Command (0x69)
MOVLW 0x0E
CALL DSTXBYTE ; Send the DS2761 Current Register MSB address (0x0E)
CALL DSRXBYTE ; Read the DS2761 Current Register MSB
MOVF IOBYTE,W
MOVWF PICMSB ; Put the Current MSB into file PICMSB
CALL DSRXBYTE ; Read the DS2761 Current Register LSB
MOVF IOBYTE,W
MOVWF PICLSB ; Put the Current LSB into file PICLSB
CALL OW_RESET
NOPDPULSE: ; Add some error processing here!
SLEEP ; Put PIC to sleep
end
