simrantogether
Hi all,
I need small pic coding examples as how i can code pic...
Any website link..
Regards,
Simran..![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Any website link..
Regards,
Simran..
simrantogether said:Hi all,
Any website link..
Regards,
Simran..![]()
simrantogether said:There are many registers lke TRISA, TRISB without which also the microcontroller can work perfectly like in AVR or Other new RISC controllers...
Yup, DDRx, short for DataDirectionRegisterA or B or whatever. Motorola/Freescale uses the same opcode.Nigel Goodwin said:TRIS registers are simply for setting the direction of the I/O pins, presumably the AVR has something similar anyway?.
There're small and big examples heresimrantogether said:just i wanted is small assembly examples...
simrantogether said:Well...
I've finally learnt MPLAB and i wanted to start with small coding examples for pic.
Does microchip issues any manual for programming pic's or any other manual.
or any other link...
Regards,
Simran..![]()
LED DRIVER said:Hello, I have the same problem as fza. I need an MPLAB assembly code that will dim a couple of LED's. The PIC is12F683. The potentiometer will be connected to PIN7(potentiometer is used so that it can manaully dimmed) and PIN5 will be connected to the dimmer, if i have read the circuit correctly. I'm in dire need of any help. Can someone give me some clue as to how i should approach this problem? maybe a small starting code that i can add things to it???? Thanks a bunch
