i2c2k said:hi,
what reasons can cause that the PIC only works, if i put my finger on the oscillator-pins of the PIC (PIC18F458). but if it works this way the operating speed is very uneven.
which reasons might that have?
thx!
edit:
by the way vcc, vdd and mclr are connected properly.
bonxer said:Do you have 22pF capacitors going from each of the oscillator pins to ground? That was an original issue I had when I started with PICs that brought me to this message board.![]()
StupidDum said:bonxer said:Do you have 22pF capacitors going from each of the oscillator pins to ground? That was an original issue I had when I started with PICs that brought me to this message board.![]()
oooo.. what will be the problem??
I connected my capacitor in this way, but it seems like just fine.
What should be the proper connection?
Nigel Goodwin said:StupidDum said:bonxer said:Do you have 22pF capacitors going from each of the oscillator pins to ground? That was an original issue I had when I started with PICs that brought me to this message board.![]()
That's how they should be connected, he was just checked that you had fitted the capacitors!.
