rxforspeed
Hey guys, I'm a noob to this forum, but I'm loving it so far; it's right up my alley! I read the MCU datasheets from Microchip Technologies, but my problem is that they're laid out for programmers/designers/engineers in assembly language. I still haven't mastered PICBasic PRO (from melabs.com), but I will soon enough. I'd like to find a good tutorial and complier for programming both the mid-and high-range MCUs (16F and 18F series, I've only used the Flash/EEPRROM versions so far) in assembly...
I've found various references on this forum regarding free assembly language compliers, does anybody have any links to any free *unlimited* compiler versions? PBP is fine for what I'm doing right now, but all the info I NEED seems to only be covered in assembly. Can anybody suggest a good book/tutorial on learing assembly (preferrably from the same manufacturer/distributor as the compiler), written in an easy-to-understand format? I've learned my way around converting decimal numbers to binary, hex, and vice-versa, so I can understand that, but some of the commands I've run across in the MCU datasheets don't seem to make much sense to me...
I'm sure I can start the learning process of assembly language while I'm still working with PBP; the differences are great enough (as it seems anyway) that it shouldn't confuse me too much. Anyway, thanks in advance for all your time, help, and cooperation. I greatly appreciate any links, suggestions, or advice that you guys can provide...
Sincerely,
-Adam Collins
Sincerely,
-Adam Collins
