LabRat
Hey gang...
Trying to get a basic "bit whacker" up and running. I've grabbed the source for the bootloader, and updated it for the 20Mhz resonator that I have connected. At this time I've kept things very bare-board. I've got a couple of diagnostic LED's attached (different pins from the original fw, so I have updated for the new locations). I also moved the "debug" switch to a (now obviously stupid) different location (pin 28, thus conflicting with the ICSP).
Most of this is redundant information as the question is.. what could lead to having a software image that will load and run just fine, when under control of the debugger (JuneBug), but won't run on it's own?
My "hello world" is - led init, led light, loop forever. Works flawlessly under debugger control, but nothing appears to happen when I disconnect the JuneBug.
Thoughts?
[Edit: 18F2550 is connected to USB for power. So it's not a case of losing power when I disconnect the debugger. ]
Andrew
Thoughts?
Andrew
