iipeacefrog
Hello all. I've been trying to figure out a way to make a circuit (assumably with the dsPIC33) to play back multiple 16-bit 44.1 khz uncompressed .wav files from an sd card (or other appropriate low cost storage if necessary). The basic idea is to have 5 buttons or so each connected to a wav file on the sd chip (or storage)......each button can trigger a wav file, and they can be played simultaneously. I am guessing each file needs a separate DAC but i'm not sure exactly how the input flow and memory storage would work with the circuit. This is for a musical application so there can be no delay between the sample playback and button press, and the sound quality needs to be comparable to cd. Any suggestions or starting points? The closest thing i've found is the dsPIC wav player
uC Hobby » Blog Archive » dsPIC WAV Player
Thanks!
Thanks!
