PIC pulse train (assembly)
riccardo
I'm trying to generate a pulse train on PORTB of a 18F2455. I had a simple Idea of running a loop and incrementing the port number, but this gives me an 'argument out of range message. Does anyone know how to do this properly?
I've just listed "channel" in a cblock and set it to 0 before this loop
Step
	BSF PORTB, channel			; Set output channel high
	CALL Wait					; Delay
	BCF PORTB, channel			; Clear output channel
	CALL Wait					; Delay
	INCF channel
	; If channel > 7 make it 0
	MOVF channel, W				; Copy channel value to W for testing
	SUBWF 8, W					; Subtract W from 8
	BTFSC STATUS, Z				; Check if result is Zero (channel needs to be reset)
		CLRF channel			; Reset to zero
	GOTO Step
You can't use a variable for the BCF or BSF instructions, just a 3 bit fixed value that's hardcoded in the line.
If you're wanting to run a bit along the port, check my tutorials for a number of ways of doing it - including multiple patterns stored in tables.
Could you point me to the tutorial that covers this? I can't find what I need.
Can I just use...?
RLNCF PORTB
Here's the code I used for anyone who might need it..
"maxChannel" is an 8-bit value representing how many channels should be pulsed before the loop restarts. 10000000 being 8 channels, while 00000001 is just one.
"channel" is the currently selected channel using the same logic as above.
Start
	CALL ResetChannels		; Reset to channel 1
Step
	MOVF channel, W		; Copy channel selection
	MOVWF PORTB			; SET outputs to selected channel combo
	CALL Wait				; Delay
	CLRF PORTB			; Clear outputs
	CALL Wait				; Delay
	RLNCF channel			; Increment Channel
	; If channel > maxChannels reset to 1
	MOVWF L4
	RRNCF L4					; Go back one because of previous increment
	MOVF L4, W
	SUBWF maxChannel, W		; Subtract W from maxChannel
	GOTO Step				; ELSE do next channel
ResetChannels
	MOVLW b'00000001'			; Start with Channel 1
	MOVWF channel
	RETURN
