amdkicksass
So i have the need to build a digital circuit that can incorporate external analog sensors. The application needs to be so that a sensor with a analog voltage output for example 0-10V can be inputted in a PIC and then using the pic and 2 external buttons, the user can set Zero and Span.
My understanding is that certain PIC modules can accept an Analog signal and the pic can interpret the digital signal as well as calculate offsets and gains needed to create the correct zero and span condition and then output the signal into a small d/A unit that report a signal with the corrected zero and span ?
Is this possible ?
PEte
Is this possible ?
PEte
