gramo
I think the following should be changed in the PIC Sticky;
The 18F series is simply an enhanced PIC that doesn’t have the downfalls of 16F PIC's. If anything, they are easier to use and are the new should be considered the "Mid Range" device as far as the introduction of 24F and dsPIC's go
You seriously don’t know what your missing out on if you haven’t delved into 18F's yet. If your using PIC's a bit, its worth it
As far as prices go, well the 18F1320 (18Pin DIP Package) is $2.69 from Newark
and the 18F4520 (40 Pin DIP) is $6.11
Later you may want to advance to 18F PIC series, which are called "High End", because they are more powerful and have better support for higher level languages
