PIC16877 question about converting to Hex file
olympus123456
I am a beginner and I want to convert the following program to HEX file and then send it to PIC16F877 . Please can anyone guide and help.
  • PIC Code.txt
Try to learn CCS C compiler or MPLab compiler...This can convert the source code to Hex code. It will give you the complete idea....
  • my1.asm
Downloaded MPLAB
I have MPLAB IDE 8.30 and also i got the PICKIT2 . Could u please guide how to compile it in MPLAB, if you could give me the steps for proceeding further, that will be very much appreciated. Thank you for fixing my errors . Please help me further toooo.
The program listing is full of errors, lots of typo's.!
Ive tidied up the program, removed the errors and it now assembles
As suggested goto: Microchip Technology Inc. - a Leading Provider of Microcontroller and Analog Semiconductors and download the MPLAB IDE V8.0
I have used MPASMWIN , from the MPLAB software i downloaded to convert to HEX file. It is giving me errors :
Error in parameter "and" , "documents and settings"
basically its not reading the source file from my desktop. What should i do to fix it ?
I have noticed that MPLAB struggles with long file addresses.
Create a newfolder on the 'C' Hard Drive, call it say MyAsm1 and move the asm file from the desktop to that folder.
Also use the MPLAB Project/Project Wizard,, when doing that point the Wizard to MyAsm1 folder and you should be OK.:)
I did as u said eric , so it created three files one of 1Kb , other of 23 Kb and one has extension .mcs
The problem is there is no hex file found but i could see asm code when i open the 23 kb file as the source file
Also i right clicked the my1.asm file and assemble in the project , and it said "build succeeded " . And there are three new files in the folder that i created .err , .LST, and .o files
How do i proceed from here now.
By using the 'Build ALL ' option and getting a build succeed you should have a *.hex file.?
To check use 'View'/ Program Memory the hex file should be displayed.
Yes, it is displaying when i went to program memory. Its a relieve though after sooo much of writing the code and you fixing it. Really , patience is the key.
Okay good news got ittttt. Hex file is there. Now, how do i send it to the PIC, I have bought PICKIT2.
Select the PICKIT2 programmer from thr MPLAB Programmer/'select programmer'
also ensure that 'RELEASE' is displayed near the top menu not debug.
Now you are on your own, I dont use that version of programmer,, good luck.:)
It is a graduation project . It measures the temperature using NTC, ECG using op-amps , Heart beat rate sensor, Saline sensor, Card attendance system . All this in PIC and should be displayed in the computer using RS-232 cable and using front end Visual Basic Interface
(which i have no knowledge of) .
Basically its tooo much of hard work , i need to find photoelectric sensors, and learn VB too. and also serial cabling . yup i have no clue .
Thanks,
A word of warning ref the program, the Oshonsoft simulator reported that the UART in the PIC had not been initialised.:rolleyes:
There are many freebie PC RS232 text display programs on the web.
ok, how come, i think i had initialized it. How do i fix it. I was told to use 9 pin female rs-232. Does this fix the problem
could u also tell me any names of such programs or links of them.
I really appreciate u man. i m sorry if i made u feel angry . i m sorry . but u can understand rite , if u work hard and it doesnt pay offf . it hurts a lot . sorry , yes i will add this part to my code , but shuld i add it the top or end.
