pasanlaksiri
Does any one have Simple programmer for this Chip
PIC16C54
PIC16C54
mvs sarma said:Hi Pasanlaksiri,
Welcome to the forum.
if you dont have many ICs of 16c54 it is better to shift to newer vesrsions. if only c54 is preferred, then cosider 16F54 which is flash and ICSP programmable. In fact it is better to consider very new versions than spend money for programmer. you may take help of any friends who can do few chips abd done with it.
mvs sarma said:did you see the AN615
operates from 2 cells-- i have modded it to work with 16F84a and with continous display. this works well the 1.8 to 3V max ie., two celss either chargeable or dry cells.
if you want,i can give you the mod hex File
pasanlaksiri said:Oh plz can u give it to me with source code and Schematics. Thanks bro
mvs sarma said:Hi, you may download the application note AN615B from www.microchip.com which is comperhensive.
modified software clk8fcont.hex is appended
No change in hardware-- apply only 3V . at 4.5 volts it is behaving erratic. at 3V or 2.4v(nicd or nimh) it works fine
yes 16F84 a-4 can be used. crystal is 32.768KHzpasanlaksiri said:Can I use PIC16F84A for this cct. And what is the meaning " continous display ". Does it mean no fickering rate or very low flickering rate?
Thanks ton my friend. I'm going to make it Tomorrow.
mvs sarma said:yes 16F84 a-4 can be used. crystal is 32.768KHz
original design is also low flicker- but after 8 sec the display will be off. that timing i removed it .
little flickering is due to low spped of refreshing.
you may read the article and only if you like you make-- other wise you can modify the 590 software to suite 16F84A-4
pasanlaksiri said:I like to make it. Hey do u have any 12Hour clocks using 16F84A
mvs sarma said:Hi someother person also wanted it-- you may modify this.as you can download original asm file
pasanlaksiri said:Hey bro, That 32.768kHz crystal is hard to find here. So do u have any idea, what r the calculations for RC. Or how to calculate it.
Nigel Goodwin said:It's a standard watch crystal - try taking an old watch or battery clock to pieces!.
It would be pointless using an RC oscillator on a clock!.
Nigel Goodwin said:Another source is old VCR's, most of them have one for the timer.
mvs sarma said:if you try (as some one said, whenthere is a will there is a way) , you will get it , as Nigel rightly said, from old and condemned casio digital watches. and few other sources of scrap.
also you can't just say that thereare no watch repairers and electronic repairers-- components are generally available-- only you have to trace for them . please don't start with negative--
