Hi to all users of this website!
I am very new to this work and yes, I realise a little knowledge is more dangerous than none!
I am currently trying to copy a programme from a PIC16C54 chip to a PIC16F54. I have a Needham's EMP-11 with version 1.6 software (last version before they ceased to exist). I do realise both these types are pretty ancient, but they do a simple job of switching relays for automotive use.
The problem I am having is the 16F54 is not on the Needhams software. I can read the verified 16C54 chip no problems & save the info. However I really need to program a chip using data from the original & plug in to a PCB to get the thing working, and wonder if anyone can advise on:
1. Is the 16F54 a good replacement, or can you advise on another that will program ok (others are listed in the Needham's software so if it is on the list & compatible I can source one of those instead). It does need to be same pin configuration.
2. Am I right in assuming I can simply read the original C type chip, save to buffer, then write to a suitable F type chip.
3. The fault with the PCB is simply the command side of things isn't working. I can't fault any of the components or PCB, so am assuming it is probably due to a problem with the PIC16C54. Is it possible that this can fail, but still allow the memory to be read with no errors?
I have a PIC Kit2 on order and so should have a more up to date & supported piece of hardware very soon so that may also help me.
Many thanks for any advice you can give.
