Pic16f tables bigger than 256
pixman
Hi
i would like to know how you would set out tables if they are morre than 255
i have read that if you have tables, they should not cross the 255 mark.
I have a program that has 5 tables, the 5th table cross this 255 area and when
i use this table it does not work properly.
Help please
DAVID
I HAD A LOOK AT THE 4 TUTORIALS.
IT STILL DOES NOT MAKE SENSE TO ME.
CAN I USE
org 0X100
AFTER TABLE 4 TO PUT IT IN A NEW 256 AREA
Place Table 5 at location 200h by using the instructions:
org 0x200
table5 addwf pcl,f
retlw .5
retlw 0ffh etc
in your main program, add:
movlw 02
movwf PCLATH
movlw jump value for table 5
call table5
Tables in baseline PIC chips can only be placed in the first 256 addresses of memory.
So would i be correct in saying that for 16f628a
start: 0x005
next : 0x200
0x400
0x600
end: 0x7ff
that is how you put tables in different places
and for the 16f877a the same would apply but continued for page 1 to page 3
I have had a good look at tutorial 13 and i can't seem to figure it out.
I will play with it in mplab to see if i can understand what you did.
Thank you for your help
