PIC16F84a
uaefame
Hello Everyone,
I decided from now on to learn PIC, I mean to understand why my program getting error and how can i improve it.
Here are my codes
    list      p=16F84A             ; list directive to define processor
    #include <p16F84a.inc>         ; processor specific variable definitions
    __CONFIG   _CP_OFF & _WDT_ON & _PWRTE_ON & _RC_OSC
STATUS	equ 03h
TRISA	equ 85h
PORTA	equ 05h
		bsf		STATUS,5
		movlw	OOh
		movwf	TRISA
		bcf		STATUS,5
START	movlw	02h
		movwf	PORTA
		movlw	00h
		movwf	PORTA
		goto	START
        END
I know its simple, but i am interested where did i make the mistake and how can i fix it.
Thanks in advance
Best regards,
Hesham Ismail
Unnecessary. These are already all defined in the file you included in the line "#include <P16F84A.INC>".
STATUS	equ 03h
TRISA	equ 85h
PORTA	equ 05h
Here you've typed in the letter O rather than the numeral 0 (zero). :p A rather silly mistake. :D
	movlw	OOh
And if you meant to clear TRISA, why not just use "clrf TRISA"?
	movwf	TRISA
If you're trying to blink an LED on RA2, you really should put a delay in there. This will just turn on the LED at about half intensity (50% duty cycle) and leave it on (as far as any human can tell, anyway). Sure it's blinking, but so fast that no human could ever see it.
START	movlw	02h
	movwf	PORTA
	movlw	00h
	movwf	PORTA
	goto	START
	END
Thanks futz,
can you show me the codes while using clrf TRISA and can you explain to me what clrf mean?
I am learning about delay now I will do my best to learn now. Wish me good luck.
Best regards,
Hesham Ismail
Look in your datasheet in Section 7.0 on Page 38.
All the opcodes are listed and described in that section.
Hello everyone
What is the different between BTFSS & BTFSC?
I started learning PIC from this website:
1-**broken link removed**
But it seem confusing a bit for me?
Do you know another Good PIC website? I mean for beginner like me?
Thanks in advance
BTFSS tests the specified bit and skips the next instruction if it is one (set).
BTFSC tests the specified bit and skips the next instruction if it is zero (clear).
edit: posted at the same time!
Hello again,
I build a circuit shown in the attachment.
I am trying to turn led on and off every 2 second here are the codes.
    __CONFIG   _CP_OFF & _WDT_ON & _PWRTE_ON & _XT_OSC
	cblock
	d1
	d2
	d3
	endc
		bsf		STATUS,5
		movlw	00h
		movwf	TRISA
		bcf		STATUS,5
START	movlw	02h
		movwf	PORTA
		call 	Delay2sec
		movlw	00h
		movwf	PORTA
		call 	Delay2sec
		goto	START
Delay2sec
			;1999996 cycles
	movlw	0x11
	movwf	d1
	movlw	0x5D
	movwf	d2
	movlw	0x05
	movwf	d3
Delay2sec_0
	decfsz	d1, f
	goto	$+2
	decfsz	d2, f
	goto	$+2
	decfsz	d3, f
	goto	Delay2sec_0
			;4 cycles (including call)
	return
	END
The problem nothing light ups can u suggest to me what is going wrong?
Btw i am using 4MHz clock.
When I build it no error mentioned when i try it out nothing happened?
Thanks in addvance
Can you explain more?
cblock address? I don't know what this mean?
Actually i am using this website to generate delay
Delay Generator
You mean i add these codes
cblock 0x0c
d1,d2,d3
endc
Thanks in advance
cblock address?
	cblock	0x0c
	d1,d2,d3
	endc
Yes. You have to tell cblock where to put those variables.
If you don't put any address I assume the assembler would put the cblock at 0x00. That wipes out your first three SFRs, which are INDF, TMR0 and PCL. You aren't using the first two, so no problem. But wiping out PCL is a HUGE problem. Your program crashes instantly.
Why count is
equ to 08h its not a general purpose registor!!!
You are correct, the first general purpose reg is 0x0C [ 0Ch]
