jwhill2000
..was wondering, I have worked with the PIC16F84 w/10MHz clock some and just tried out the 16F84A w/20MHz clock. I noticed that the 16F84A was really putting off some heat, almost too hot to touch. Is this normal? Thank.
jwhill2000;342581 Is this normal? [/quote said:No. You do realize the power connections are amidship on the '84?
Thanks for replies. Yes, it appears to me that the power connections between the two are identical - from the datasheets. My circuit is just a simple serial output to a terminal. I didn't change anything when I went from 84 to 84A, other than removing the 10MHz osc w/a 20MHz osc. The program worked fine, but the chip was hot.
If a PIC is getting too hot to touch, it's almost certainly been plugged in the wrong way round - PIC's generally run stone cold, although they may get slightly warm if they are supplying a lot of current.
Possible Nigel. I was of the opinion that if a 16f84A-4 is worked with 20MHz oscillator, it might turn HOT.
It is a permitted design feature of the chip. Hence nothing should happen.I run the 18F1320 at 40Mhz (10Mhz and 4x PLL) regularly and they get slightly warm but never hot.
I am in the process of reworking my breadboard and making it a bit neater. I'll let you know what I did or did not do wrong. Thanks.
