PIC16f872 does not run correct after programming...
Spock540
Hello at first i am very new to this kind and maybe its a stpid question but i cant figure out. I build a board with a PIC16f872 where it is possible to programm the chip with. The programming is fine i compared too HEX files from different locations so i am sure the program reaches the Chip..... but when i write a testprogram like SET_TRIS_B (0x0f) in a while(1) loop the chip does not toggle those pins they are low all???? I can not get any program to run on that "animal".... Any suggestions or help is appreciated.
Spock540
[/code]
Setting the tris will make those pins inputs, so they will be 'low' when measured.
You should clear the tris for the pins (make it '0') and then in your loop write '1' to the port (not the tris) delay (important, pic runs to fast to see anyting happen without delay) and then write '0' to the port.
If your sure your software is correct and it doesn't run then there may be a oscillator problem. What oscillator are you using and how fast is it?
common problems are :
No oscillator :roll:
wrong config fuses (0-4Mhz XT, 4MHZ+ HS)
