procos said:any little sample?
; Generate interrupts every 10mS, display count of hours, minutes, seconds, and hundreths.
LIST p=16F876 ;tell assembler what chip we are using
include "P16F876.inc" ;include the defaults for the chip
ERRORLEVEL 0, -302 ;suppress bank selection messages
__CONFIG 0x393A ;sets the configuration settings (oscillator type etc.)
;***** VARIABLE DEFINITIONS
cblock 0x20 ; define a series of variables.
w_temp ; variable used for context saving
status_temp ; variable used for context saving
Hours ; hours counter
Mins ; minutes counter
Secs ; seconds counter
MSecs ; 10's of millisconds counter
count0 ; Interrupt counter
flagsecs ; Contains a 0 unless 500 1-ms Timer 2
; interrupts have been processed.
flag10s ; ten second flag
flag60s ; sixty second flag
HoursA ; alarm hours register
MinsA ; alarm minutes register
SecsA ; alarm seconds register
count ;used in looping routines
count1 ;used in delay routine
counta ;used in delay routine
countb ;used in delay routine
tmp1 ;temporary storage
tmp2
templcd ;temp store for 4 bit mode
templcd2
NumL ;Binary inputs for decimal convert routine
NumH
TenK ;Decimal outputs from convert routine
Thou
Hund
Tens
Ones
endc
; Bits within PORTA
ToggleBit equ 1 ; An output bit, toggled every 500 ms.
TenSecBit equ 2
MinuteBit equ 4
PortAMask equ B'00000000' ; We'll make all of PORT A an output.
LCD_PORT Equ PORTB ;LCD on PortB
LCD_TRIS Equ TRISB
LCD_RS Equ 0x04 ;LCD handshake lines
LCD_RW Equ 0x06
LCD_E Equ 0x07
SW_PORT Equ PORTC
SW_TRIS Equ TRISC
LED1 Equ 0x00
LED2 Equ 0x01
LED3 Equ 0x02
LED4 Equ 0x03
BUT1 Equ 0x04
BUT2 Equ 0x05
BUT3 Equ 0x06
BUT4 Equ 0x07
ORG 0x000 ; processor reset vector
clrf PCLATH ; ensure page 0 is used
goto main ; go to beginning of program
ORG 0x004 ; interrupt vector location
movwf w_temp ; save off current W register contents
swapf STATUS,W ; move status register into W register
clrf STATUS ; select Bank 0
movwf status_temp ; save off contents of STATUS register
; There's no need to save PCLATH since
; we'll stick to Bank 0 of program memory.
; isr code can go here or be located as a call subroutine elsewhere
btfsc PIR1,TMR2IF ; If Timer 2 caused the interrupt, handle it.
call Timer2
swapf status_temp,w ; retrieve copy of STATUS register
movwf STATUS ; restore pre-isr STATUS register contents
swapf w_temp,f
swapf w_temp,w ; restore pre-isr W register contents
retfie ; return from interrupt
; Timer 2 Interrupt handler.
; Timer 2 has overflowed
Timer2
incf count0,F ; increment interrupt counter
movlw d'5' ; Is count0 5 yet?
subwf count0,W
btfss STATUS,Z ; If count0 is not 5, end ISR.
goto EndTimer2Interrupt
; Reinitialize count0
clrf count0
incf MSecs,F ; increment milli second counter
movlw d'100' ; Is MSecs 100 yet?
subwf MSecs,W
btfss STATUS,Z ; If MSecs is not 100, end ISR.
movlw H'FF'
movwf flagsecs
; Reinitialize Secs
clrf MSecs
incf Secs,F ; increment 10 second counter
movlw d'60' ; Is Secs 60 yet?
subwf Secs,W
btfss STATUS,Z ; If Secs is not 60, end ISR.
movlw H'FF'
movwf flag10s
; Reinitialize Secs
clrf Secs
incf Mins,F ; increment 60 second counter
movlw d'60' ; Is Mins 60 yet?
subwf Mins,W
btfss STATUS,Z ; If Mins is not 60, end ISR.
movlw H'FF'
movwf flag60s
; Reinitialize Mins
clrf Mins
incf Hours,F ; increment hour counter
movlw d'24' ; Is Mins 24 yet?
subwf Hours,W
btfss STATUS,Z ; If Hours is not 24, end ISR.
movlw H'FF'
movwf flag60s
; Reinitialize Hours
clrf Hours ; reset hours to zero
EndTimer2Interrupt
bcf PIR1,TMR2IF ; Clear flag and continue.
return
; HEX conversion table for LCD routines.
HEX_Table ADDWF PCL , f
RETLW 0x30
RETLW 0x31
RETLW 0x32
RETLW 0x33
RETLW 0x34
RETLW 0x35
RETLW 0x36
RETLW 0x37
RETLW 0x38
RETLW 0x39
RETLW 0x41
RETLW 0x42
RETLW 0x43
RETLW 0x44
RETLW 0x45
RETLW 0x46
main
; START OF CODE to initialize the processor
; The initialization code goes here since we'll end up here shortly after a reset.
; Most Bank 0 initializations are done here and they come first.
bcf STATUS,RP0 ; Select Bank 0
bcf STATUS,RP1
BANKSEL ADCON1 ;disable A2D for 16F876/7
movlw 0x06
movwf ADCON1
BANKSEL PORTA
clrf PORTA ; Initialize Port A by clearing the output latches.
clrf count0
clrf MSecs
clrf Secs
clrf Mins
clrf Hours
clrf flagsecs ; Turn off the flag which, when set, says 500 ms has elapsed.
clrf flag10s
clrf flag60s
clrf HoursA ;clear alarm registers
clrf SecsA
clrf MinsA
; Most Bank 1 initializations come next.
bsf STATUS,RP0 ; Select Bank 1
movlw PortAMask ; Initialize direction pins for Port A using TRISA.
movwf TRISA
movlw 0xF0
movwf SW_TRIS ;set inputs for buttons
movlw 0x00 ;make all LCD pins outputs
movwf LCD_TRIS
bcf STATUS,RP0 ; Revert to Bank 0
movlw b'00000000'
movwf SW_PORT ;clear LED's
;test alarm values
movlw 0x01 ;set 1 hour
movwf HoursA
movlw 0x02
movwf MinsA ;set 2 minute
movlw 0x1E ;set 30 seconds
movwf SecsA
; START OF CODE to initialize Timer 2
; These come next only because it's convenient to group them together, not because
; it's a necessity.
; Set up Timer 2 to generate interrupts every 1 ms. Since we're assuming an instruction
; cycle consumes 1 us, we need to cause an interrupt every 1000 instruction cycles.
; We'll set the prescaler to 4, the PR2 register to 25, and the postscaler to 10. This
; will generate interrupts every 4 x 25 x 10 = 1000 instruction cycles.
clrf TMR2 ; Clear Timer2 register
bsf STATUS, RP0 ; Bank1
bsf INTCON,PEIE ; Enable peripheral interrupts
clrf PIE1 ; Mask all peripheral interrupts except
bsf PIE1,TMR2IE ; the timer 2 interrupts.
bcf STATUS, RP0 ; Bank0
clrf PIR1 ; Clear peripheral interrupts Flags
movlw B'01001001' ; Set Postscale = 10, Prescale = 4, Timer 2 = off.
movwf T2CON
movlw D'250'-1 ; Set the PR2 register for Timer 2 to divide by 250.
movwf PR2
bsf INTCON,GIE ; Global interrupt enable.
bsf T2CON,TMR2ON ; Timer2 starts to increment
; END OF CODE to initialize Timer 2
call LCD_Init ;setup LCD
; main()
; This is the main program. It does only one thing: check to see if it's time to
; toggle PORTA<togglebit> and do so if it is time. Otherwise it's busily engaged
; in using up all the instruction cycles not required by the interrupt handlers.
loop
call Check_Keys
movf flagsecs, W ; Has the flagsecs been set?
btfsc STATUS,Z
goto loop ; Not yet. Keep looking.
call Check_Alarm ; check alarm every LCD update
call LCD_Line1
movlw 'T'
call LCD_Char
movlw 'i'
call LCD_Char
movlw 'm'
call LCD_Char
movlw 'e'
call LCD_Char
movlw ' '
call LCD_Char
movlw ' '
call LCD_Char
movf Hours, w
movwf NumL
call Display
movlw ':'
call LCD_Char
movf Mins, w
movwf NumL
call Display
movlw ':'
call LCD_Char
movf Secs, w
movwf NumL
call Display
movlw ' '
call LCD_Char
call LCD_Line2
movlw 'A'
call LCD_Char
movlw 'l'
call LCD_Char
movlw 'a'
call LCD_Char
movlw 'r'
call LCD_Char
movlw 'm'
call LCD_Char
movlw ' '
call LCD_Char
movf HoursA, w
movwf NumL
call Display
movlw ':'
call LCD_Char
movf MinsA, w
movwf NumL
call Display
movlw ':'
call LCD_Char
movf SecsA, w
movwf NumL
call Display
movlw ' '
call LCD_Char
goto loop ; Now wait for the next occurence.
Check_Keys
btfss SW_PORT, BUT1
goto Clear_Clk
btfss SW_PORT, BUT2
bcf T2CON,TMR2ON ; stop Timer2
btfss SW_PORT, BUT3
bsf T2CON,TMR2ON ; start Timer2
return
Clear_Clk
clrf Hours
clrf Mins
clrf Secs
clrf MSecs
clrf count0
clrf flagsecs
clrf flag10s
clrf flag60s
clrf SW_PORT ; turn off and LED's
return
Check_Alarm
movf Hours, w ;check hours
subwf HoursA, w
btfss STATUS, Z
return
movf Mins, w ;check minutes
subwf MinsA, w
btfss STATUS, Z
return
movf Secs, w ;check seconds
subwf SecsA, w
btfsc STATUS, Z
bsf SW_PORT, LED1
return
Display clrf NumH
call Convert ;convert to decimal
movf Tens, w
call LCD_CharD
movf Ones, w
call LCD_CharD
return
;LCD routines
;Initialise LCD
LCD_Init call LCD_Busy ;wait for LCD to settle
movlw 0x20 ;Set 4 bit mode
call LCD_Cmd
movlw 0x28 ;Set display shift
call LCD_Cmd
movlw 0x06 ;Set display character mode
call LCD_Cmd
movlw 0x0c ;Set display on/off and cursor command
call LCD_Cmd ;Set cursor off
call LCD_Clr ;clear display
retlw 0x00
; command set routine
LCD_Cmd movwf templcd
swapf templcd, w ;send upper nibble
andlw 0x0f ;clear upper 4 bits of W
movwf LCD_PORT
bcf LCD_PORT, LCD_RS ;RS line to 1
call Pulse_e ;Pulse the E line high
movf templcd, w ;send lower nibble
movwf LCD_PORT
call LCD_Busy
retlw 0x00
LCD_CharD addlw 0x30 ;add 0x30 to convert to ASCII
LCD_Char movwf templcd
movwf LCD_PORT
bsf LCD_PORT, LCD_RS ;RS line to 1
movwf LCD_PORT
call LCD_Busy
retlw 0x00
LCD_Line1 movlw 0x80 ;move to 1st row, first column
call LCD_Cmd
retlw 0x00
LCD_Line2 movlw 0xc0 ;move to 2nd row, first column
call LCD_Cmd
retlw 0x00
LCD_Line1W addlw 0x80 ;move to 1st row, column W
call LCD_Cmd
retlw 0x00
LCD_Line2W addlw 0xc0 ;move to 2nd row, column W
call LCD_Cmd
retlw 0x00
LCD_CurOn movlw 0x0d ;Set display on/off and cursor command
call LCD_Cmd
retlw 0x00
LCD_CurOff movlw 0x0c ;Set display on/off and cursor command
call LCD_Cmd
retlw 0x00
LCD_Clr movlw 0x01 ;Clear display
call LCD_Cmd
retlw 0x00
LCD_HEX movwf tmp1
swapf tmp1, w
andlw 0x0f
call HEX_Table
call LCD_Char
movf tmp1, w
andlw 0x0f
call HEX_Table
call LCD_Char
retlw 0x00
Pulse_e bsf LCD_PORT, LCD_E
nop
bcf LCD_PORT, LCD_E
retlw 0x00
LCD_Busy
bsf STATUS, RP0 ;set bank 1
movlw 0x0f ;set Port for input
movwf LCD_TRIS
bcf STATUS, RP0 ;set bank 0
bcf LCD_PORT, LCD_RS ;set LCD for command mode
bsf LCD_PORT, LCD_RW ;setup to read busy flag
bsf LCD_PORT, LCD_E
swapf LCD_PORT, w ;read upper nibble (busy flag)
bcf LCD_PORT, LCD_E
movwf templcd2
bsf LCD_PORT, LCD_E ;dummy read of lower nibble
bcf LCD_PORT, LCD_E
btfsc templcd2, 7 ;check busy flag, high = busy
goto LCD_Busy ;if busy check again
bcf LCD_PORT, LCD_RW
movlw 0x00 ;set Port for output
movwf LCD_TRIS
return
Delay255 movlw 0xff ;delay 255 mS
goto d0
Delay100 movlw d'100' ;delay 100mS
goto d0
Delay50 movlw d'50' ;delay 50mS
goto d0
Delay20 movlw d'20' ;delay 20mS
goto d0
Delay5 movlw 0x05 ;delay 5.000 ms (20 MHz clock)
d0 movwf count1
d1 movlw 0xE7 ;delay 1mS
movwf counta
movlw 0x04
movwf countb
Delay_0
decfsz counta, f
goto $+2
decfsz countb, f
goto Delay_0
decfsz count1 ,f
goto d1
retlw 0x00
;end of LCD routines
Convert: ; Takes number in NumH:NumL
; Returns decimal in
; TenK:Thou:Hund:Tens:Ones
swapf NumH, w
iorlw B'11110000'
movwf Thou
addwf Thou,f
addlw 0XE2
movwf Hund
addlw 0X32
movwf Ones
movf NumH,w
andlw 0X0F
addwf Hund,f
addwf Hund,f
addwf Ones,f
addlw 0XE9
movwf Tens
addwf Tens,f
addwf Tens,f
swapf NumL,w
andlw 0X0F
addwf Tens,f
addwf Ones,f
rlf Tens,f
rlf Ones,f
comf Ones,f
rlf Ones,f
movf NumL,w
andlw 0X0F
addwf Ones,f
rlf Thou,f
movlw 0X07
movwf TenK
; At this point, the original number is
; equal to
; TenK*10000+Thou*1000+Hund*100+Tens*10+Ones
; if those entities are regarded as two's
; complement binary. To be precise, all of
; them are negative except TenK. Now the number
; needs to be normalized, but this can all be
; done with simple byte arithmetic.
movlw 0X0A ; Ten
Lb1:
addwf Ones,f
decf Tens,f
btfss 3,0
goto Lb1
Lb2:
addwf Tens,f
decf Hund,f
btfss 3,0
goto Lb2
Lb3:
addwf Hund,f
decf Thou,f
btfss 3,0
goto Lb3
Lb4:
addwf Thou,f
decf TenK,f
btfss 3,0
goto Lb4
retlw 0x00
END ; directive 'end of program''
