PIC16F877A Based Frequency Measurement
Sujit Mishra
Dear sir, I am trying to use CCP module of PIC16F877A uC in capture mode too read input frequency. I have written a small code for it but unfortunately its not working. Can anyone guide me what mistake am I making in it. Below is my code, Thanks.
#include <htc.h>
#include "LCD.h"
__CONFIG(FOSC_HS & WDTE_OFF & PWRTE_OFF & BOREN_ON
& LVP_OFF & CPD_ON & WRT_OFF & CP_ON); // configuration bits
#define _XTAL_FREQ 4000000 // 4MHZ external crystal
void InitGPIO(void)
__delay_ms (10); // Power up delay
TRISCbits.TRISC2 = 1; // CCP1: Configure as input pin
ADCON1 = 0x0F;
void CCPInit(void)
CCP1IE = 0; //Disables the CCP1 interrupt
CCP1IF = 0; //No TMR1 resister capture occurred
T1CON = 0x01;
CCP1CON = 0x05; //Capture mode, every rising edge
void main (void)
unsigned int start, end, period;
float result, frequency;
InitGPIO();
InitLCD();
CCPInit();
lcd_gotoxy(0,4);
WriteStringToLCD("FREQUENCY");
while(1)
while(!(CCP1IF)); // Wait first rising edge
CCP1IF = 0; // Clear flag not next round
start = CCPR1L; // Save value of first rising edge
//CCP1CON = 0x00; // Disable CCP1 capture module
end = CCPR1H; // Save value of second rising edge
period = (end - start);
period = (float)period;
frequency = (1/period);
lcd_gotoxy(1,4);
disp_num(frequency);
__delay_ms(1);
  • LCD.c
  • LCD.h
First... How fast do you need this...
4Mhz crystal.. 1us TOSC.... Therefore TMR1 will time out in approximately 65mS that makes 15Hz your lowest frequency..
When CCP1IF fires you save the lower val in start and the higher val in end???
Lastly this line frequency = (1/period); will not yield the correct result... Period is an integer and the constant 1 will also be an integer..
Here is how I did t..
C:
       frequency = (divisor * period);
       result = (int)(1/frequency);
The reason for the divisor is because I set T1CON to 0x31 to give an 8:1 pre-count so I could have slower frequency
The divisor needs to be set to 0.000008 to allow for the 8:1
Also clear the timer before you measure.. This way the result will never cross the zero.. Capture the whole CCP1 reg not just the lower or the higher one..
C:
TMR1 = 0;
       start = CCPR1; // Save value of first rising edge
       end = CCPR1; // Save value of second rising edge
