Pic16f877a-usart
tio_rafael
Hi all
I'm trying to receive some data from a gps module and send it to my PC using PIC16F877A USART. These are the relevant parameters of my project:
9600bps, 8N1 and no flow control.
My code:
(clk=4MHz)
#INCLUDE <P16F877A.INC>
__CONFIG _CP_OFF & _CPD_OFF & _DEBUG_OFF & _LVP_OFF & _WRT_OFF & _BODEN_OFF & _PWRTE_ON & _WDT_OFF & _XT_OSC
BCF STATUS,RP1
#DEFINE BANK0 BCF STATUS,RP0 ;SET BANK0
#DEFINE BANK1 BSF STATUS,RP0 ;SET BANK1
BAUD_RATE_SPBRG EQU .25 ;SPBRG
CBLOCK 0X70
DATA_BYTE ;RECEIVED BYTE
ENDC
ORG 0X0000
GOTO SERIAL_INIT
CLRF DATA_BYTE
CLRF PORTC
SERIAL_INIT
BANK1
MOVLW B'10000000'
MOVWF TRISC ;TX RC6 AND RX RC7
MOVLW B'00000110'
MOVWF ADCON1 ;DIGITAL I/O
MOVLW BAUD_RATE_SPBRG
MOVWF SPBRG ;BAUD RATE CONFIG
MOVLW B'00000000'
MOVWF INTCON ;NO INTERRUPTIONS
MOVLW B'00100100'
MOVWF TXSTA ;ACTIVATE TX AND HIGHT BAUD RATE
BANK0
MOVLW B'10010000'
MOVWF RCSTA ;ACTIVATE SERIAL AND RX
GOTO RECEIVE
RECEIVE
BANK1
BTFSS PIR1,5 ;DOES RECEPTION BUFFER IS FULL?
GOTO RECEIVE ;NO-WAIT
GOTO CHECK_OERR ;YES-CHECK OERR
CHECK_OERR
BANK0
BTFSS RCSTA,1 ;DOES OERR OCCURRED?
GOTO CHECK_FERR ;NO-CHECK FERR
GOTO SERIAL_INIT ;YES-RESET
CHECK_FERR
BANK0
BTFSS RCSTA,2 ;DOES FERR OCCURRED?
GOTO GET_DATA ;NO-GET RECEIVED DATA
GET_DATA
BANK0
MOVLW RCREG
MOVWF DATA_BYTE
GOTO TRANSMIT
TRANSMIT
BANK0
BTFSC PIR1,4 ;DOES TXREG IS EMPTY?
GOTO TRANSMIT ;NO-WAIT
MOVLW DATA_BYTE ;YES-SET DATA TO TRANMIT
MOVWF TXREG
GOTO TRANSMIT_LOOP
TRANSMIT_LOOP
BANK1
BTFSS TXSTA,1 ;DOES DATA WERE SENT?
GOTO TRANSMIT_LOOP ;NO-WAIT
GOTO RECEIVE ;YES-RECEIVE
END
What is wrong with the code ?? Only the sending part is working, I tested it separately.
Nigel Goodwin said:
You should use the 'code' tags to format your code correctly - but if you check my tutorials the last RS232 one shows how to use the 877 UART.
You have a very good tutorial there, but it doesn't check errors like OERR and FERR. According to the datasheet OERR, when is set, won't let you receive more data. So, is essential to check this bit, and if this error occurs you must reset your receiver. Correct?
	CBLOCK 	0X70
	ENDC
	ORG	0X0000
	GOTO	SERIAL_INIT
	CLRF	DATA_BYTE
	CLRF	PORTC
	BCF 	STATUS,RP1
SERIAL_INIT
	BANK1
	MOVLW	B'10000000'
	MOVLW	B'00000110'
	MOVLW	B'00000000'
	MOVLW	B'00100100'
	BANK0
	MOVLW	B'10010000'
	GOTO 	RECEIVE
RECEIVE
	BANK1
	BTFSS	PIR1,RCIF	;DOES RECEPTION BUFFER IS FULL?
CHECK_OERR
	BANK0
	BTFSS	RCSTA,OERR	;DOES OERR OCCURRED?
CHECK_FERR
	BANK0
	BTFSS	RCSTA,FERR	;DOES FERR OCCURRED?
GET_DATA
	BANK0
	MOVLW	RCREG
	MOVWF	DATA_BYTE
	GOTO 	TRANSMIT
TRANSMIT
	BANK0
	BTFSC	PIR1,TXIF	;DOES TXREG IS EMPTY?
	MOVWF	TXREG
	GOTO 	TRANSMIT_LOOP
TRANSMIT_LOOP
	BANK1
	BTFSS	TXSTA,TRMT	;DOES DATA WERE SENT?
	END
Thanks for the 'code' tag trick .... ;)
Those sort of things are really from 30/40 years ago - it's uncommon now to bother with either error flags or handshaking - and if your serial link isn't very good then the error flags are pretty useless anyway, they are much too restricted to give meaningful results.
hi tio,
Made a few changes to you code, its very simple, but it works.
You should be able to expand/improve on it as required.
Regards
EDIT: this subr should read.
RXERR1:
BSF RCSTA,CREN
MOVLW '?'
MOVWF DATA_BYTE; + this line
GOTO ISTXRDY
ericgibbs said:
hi tio,
Regards
RXERR1:
BSF RCSTA,CREN
MOVLW '?'
GOTO ISTXRDY
Thanks a lot! Your code really works.
Thank you all for your time and helpful comments!
