Yes, select Vdd as the reference to the A/D converter and the 600 mV reference as the input (setting CHS0/3, as you said).spuffock said:Am I correct in assuming that I can read the 600mV reference on address 1111, and use this to determine the true VCC?
The fixed Vref can be used as the reference to for the comparators too. CVref and the fixed Vref are multiplexed (see bits C1Rsel and C2Rsel).Pommie said:it appears that the only place that the Fixed Vref goes is to the ADC input - is this correct?
Pommie said:The reason I ask is because I'm using the comparators with the ladder Vref and the diagrams in the data sheet suggest that this would still work to measure Vdd.
