mrfunkyjay
Just like the title, I would like to turn on several leds by pressing the 3rd channel (assigned) button on transmitter. This is done by catching the pulse from channel 3 output from receiver and do several logic inside pic18f1330. I have already my C language code, but my led goes on forever after i pressed my button(3ch). Please advice me, thank you very much.
I planned to do dimming, but now i cannot proceed with the logic, help!!!
#include <p18f1330.h>
#include <delays.h>
#pragma config OSC = INTIO2
#pragma config WDT = OFF
int cState;
void vStandby (void);
void vDimmer30 (void);
void vDimmer60 (void);
void vDimmer100 (void);
int iPulse;
/*Counts the length of a pulse on Pin RA1*/
int GetPulse(){
T1CON=0b00000000; /*Init timer1*/
TMR1L=0;
TMR1H=0;
TRISAbits.TRISA1=1; /*Make this pin as an input*/
while(PORTAbits.RA0==1); /*Make pin low*/
while(PORTAbits.RA0==0); /*While pin is high*/
T1CONbits.TMR1ON=1; /*Start timer1*/
while(PORTAbits.RA0==1); /*When pin is low*/
T1CONbits.TMR1ON=0; /*Stop timer1*/
return TMR1H*256+TMR1L; /*return 16bit timer value*/
void main(void)
OSCCONbits.IRCF2 = 1; /*Set OSC Frequency to 4 MHz*/
OSCCONbits.IRCF1 = 1;
OSCCONbits.IRCF0 = 0;
OSCCONbits.IOFS = 1; /*Frequency Stable*/
OSCCONbits.SCS1 = 0; /*Using Primary OSC*/
OSCCONbits.SCS0 = 0;
TRISA = 0b00000001; /*Initialize RA0 as Input Port to read PWM Signal*/
TRISB = 0b00000000; /*Initialize Port B as Output Port to flash LEDs*/
ADCON1 = 15; /*Digital Input*/
PORTA = 0;
PORTB = 0;
while(1)
iPulse = GetPulse();
if (iPulse <= 1400)
cState = 0;
if (iPulse >= 1600 && cState == 0)
vDimmer100();
cState = 1;
if (iPulse <= 1400 && cState == 1)
cState = 2;
if (iPulse >= 1600 && cState == 2)
vStandby();
cState = 3;
if (iPulse <= 1400 && cState == 3)
cState = 0;
LATBbits.LATB0 = 0;
LATBbits.LATB1 = 0;
LATBbits.LATB4 = 0;
LATBbits.LATB5 = 0;
PTPERH = 0b00000011; /*Set Period PTPER to 255*/
PTPERL = 0b11110000;
PTCON0bits.PTMOD1 = 0; /*Free-Running Mode*/
PTCON0bits.PTMOD0 = 0;
PWMCON0bits.PWMEN2 = 0; /*PWM0,1,2,3 port as Output PWM*/
PWMCON0bits.PWMEN1 = 1;
PWMCON0bits.PWMEN0 = 1;
PTCON0bits.PTCKPS1 = 0; /*Set Prescaler to 4*/
PTCON0bits.PTCKPS0 = 1;
PTPERH = 0b00001111; /*Set Period PTPER to 255*/
PTPERH = 0b11111111; /*Set Period PTPER to 255*/
PTPERL = 0b11111111;
