Hello, I'm new to this forum and seeking help urgently. Can someone tell me why my interrupt receive is not working?
I'm communicating with my computer through real term at 115200 bps.
mplab IDE v8.70 compiler
thanks in advance for anyone helping.
I got my interrupt to work, but not correctly. The values that I am getting back from the interrupts are all mostly wrong. Can someone kind of enough help me.
I have two main problems. Whenever my RX interrupt assign data to the array (hs_hold[2]). The values are correct only sometimes , when they are outputted through the TX interrupt. I have also setup the TX interrupt to also display the hs_count which is used to increment the array. But even that has it's values non- consistent.
I am really confused, any helps is appreciated.
unsigned int hs_count; // handshake counter
volatile int handshake; // handshake flag
volatile int talk_continue; // continue flag
unsigned char temp_error; // used in case to hold RC2REG in case of overrun error
unsigned char ID_A[2]; // array used to hold motor id, angle byte1, angle byte2
int i;
unsigned char hs_hold[2];
void setupUSART2(void)
{ //setup for EUART2 - target baudrate 115200 - used for communication with computer
TXSTA2 = 0b00100000; //Enable transmit and low baud rate
RCSTA2 = 0b10010000; //Enable serial port
BAUDCON2 = 0b00001000; //Enable 16 bit baud generator
SPBRGH2 = 0;
SPBRG2 = 25;
RCONbits.IPEN = 0; //enable Interrupt - disable Interrupt priority levels
// PIR3bits.RC2IF = 0; // clears recieve interrupt flag
INTCONbits.GIE = 1; // enable Global Interrupts
INTCONbits.PEIE = 1; //enable Peripheral Interrupt
PIE3bits.RC2IE = 1; // enable EUSART Interrupt for Recieve
IPR3bits.RC2IP = 0;
IPR3bits.TX2IP = 0;
#pragma code isr=0x08
#pragma interrupt isr
void isr(void)
if((PIR3bits.RC2IF ==1) && (PIE3bits.RC2IE ==1))
if(RCSTA2&0x06) // check if(RCSTAbits.FERR==1 || RCSTAbits.OERR==1 ) // when OEER ==1 EUSART Recieve is disabled. FERR =1 Framign error
{ //this shouldn't really happen since, handshake protocol would prevent overrun errors
//just in case, will allow EUSART Recieve to function.
RCSTA2bits.CREN =0; //overrun error - clear CREN
hs_hold[hs_count] = RCREG2 ; //clear Framing error
RCSTA2bits.CREN = 1; //Renable CREN
else
hs_hold[hs_count] = RCREG2;
if(hs_count >= 2) //used to reset hs_count
{ hs_count = 0;
else
hs_count++;
talk_continue = 1; //continue protocol communiaction with computer
PIE3bits.TX2IE = 1; // enable EUSART Interrupt for Transmit
// Transmisson Interrupt
//interrupt used to continue communication protocol with computer. By sending FA.
if(talk_continue == 1)
if ((PIR3bits.TX2IF == 1) && (TXSTA2bits.TRMT == 1) &&(PIE3bits.TX2IE == 1)) //check if TX2REG is OPEN, and if TX interrupt flag is set
if(handshake == 0)
TXREG2 = 0xFA; //FA is used to established inital handshake protocol of FF-AA-FF
while(TXSTA2bits.TRMT == 0)
TXREG2 = hs_count;
TXREG2 = hs_hold[hs_count];
else
TXREG2 = 0xFB; //FB is used when ready to recieve motor ID/Angle
talk_continue = 0; //resets talk_continue.
PIE3bits.TX2IE = 0 ; // disable EUSART Interrupt for Transmit- to avoid continous interrupt
#pragma code
void main(void)
{ OSCCONbits.SCS = 0b00; // Selects Primary clock(FOSC) as the clock source
TRISCbits.TRISC7 = 1;
TRISCbits.TRISC6 = 0;
TRISBbits.TRISB5 = 1;
TRISBbits.TRISB4 = 0;
PPSUnLock(); // Reassign pins for EUSART2
PPSOutput( PPS_RP7, PPS_TX2CK2); //Remaps TX2 to RP7
PPSInput( PPS_RX2DT2, PPS_RP8); //Remaps RX2 to RP8
PPSLock();
setupUSART1();
setupUSART2();
talk_continue = 0;
handshake = 0;
hs_count = 0;
while(1){
while(handshake == 0)
{ if((hs_hold[1]== 0xAA) && ( hs_hold[0] == hs_hold[2] == 0xFF) ) //check if handshake protocl activated FF-AA-FF
{ handshake = 1;
PIE3bits.RC2IE = 0; // Disable EUSART Interrupt for Recieve. Handshake protocol established.
hs_hold[0] = 0x00; //reset hs_hold
hs_hold[1] = 0x00;
hs_hold[2] = 0x00;
while(handshake == 1)
{ //check if TXREG2 holds a 0xFE which ends transmit protocol.
for(i =0; i<2; i++)
while(PIR3bits.RC2IF == 0) //waiting buffer, for when Recieve flag is set.
if(PIR3bits.RC2IF ==1) //checks if Register flag is enabled, register holds a byte
ID_A[i] = RCREG2;
talk_continue = 1;
if ( (ID_A[2] == 0xAA) && (ID_A[0] == ID_A[2] == 0xFF) )
action(); //tells motors to move
handshake = 0;
else
store_move(ID_A[0], ID_A[1], ID_A[2]);
