oussamasgh
hello ,
I work with mplab c 18
can u plz help me with those error
C:\Documents and Settings\oussama\Bureau\projet3\projet3.c:86:Warning [2066] type qualifier mismatch in assignment
C:\Documents and Settings\oussama\Bureau\projet3\projet3.c:114:Error [1151] struct or union object designator expected
C:\Documents and Settings\oussama\Bureau\projet3\projet3.c:115:Error [1151] struct or union object designator expected
C:\Documents and Settings\oussama\Bureau\projet3\projet3.c:116:Error [1151] struct or union object designator expected
C:\Documents and Settings\oussama\Bureau\projet3\projet3.c:117:Error [1151] struct or union object designator expected
C:\Documents and Settings\oussama\Bureau\projet3\projet3.c:118:Error [1151] struct or union object designator expected
C:\Documents and Settings\oussama\Bureau\projet3\projet3.c:119:Error [1151] struct or union object designator expected
C:\Documents and Settings\oussama\Bureau\projet3\projet3.c:120:Error [1151] struct or union object designator expected
C:\Documents and Settings\oussama\Bureau\projet3\projet3.c:121:Error [1151] struct or union object designator expected
C:\Documents and Settings\oussama\Bureau\projet3\projet3.c:122:Error [1151] struct or union object designator expected
C:\Documents and Settings\oussama\Bureau\projet3\projet3.c:129:Error [1151] struct or union object designator expected
C:\Documents and Settings\oussama\Bureau\projet3\projet3.c:132:Error [1151] struct or union object designator expected
C:\Documents and Settings\oussama\Bureau\projet3\projet3.c:133:Error [1151] struct or union object designator expected
C:\Documents and Settings\oussama\Bureau\projet3\projet3.c:141:Error [1105] symbol 'ADIF' has not been defined
Halting build on first failure as requested.
BUILD FAILED: Fri Apr 03 18:47:45 2009
it is about th convert A/N
void init_timer0(void)
T0CON.TMR0ON=1;
T0CON.PSA =0;
T0CON.T0CS= 0;
T0CON.PS2 = 1;
T0CON.PS1 = 1;
T0CON.PS0= 1;
T0CON.RP0 = 0 ;
T0CON.T0IE = 1;
T0CON.GIE = 1;
T0CON.TMR0ON=1;
T0CON.PSA =0;
T0CON.T0CS= 0;
T0CON.PS2 = 1;
T0CON.PS1 = 1;
T0CON.PS0= 1;
T0CON.RP0 = 0 ;
T0CON.T0IE = 1;
T0CON.GIE = 1;
